10-31-2005, 05:04 PM
Child of the 60's
1965 17' Caravel
Bexley
, Ohio
Magic Chef Pilot Light Supply Tube
Anyone know where I can find a 1/8 propane supply line (feeds the propane up to the top of the pilot light) for a Magic Chef out of a 65 Caravel? My supply line broke off at the back of the stove (probably from too much vibration). The model is a 160 and I haven't had any luck finding any replacement parts for it. Any suggestions you have would be greatly appreciated. Thanks all!
10-31-2005, 07:34 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
Got any of the old mom and pop hardware stores around? Maybe an old appliance repair shop?
Did they ever rebuilt the KonTikki restaurant? That place was really cool!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
11-01-2005, 05:03 AM
1960 24' Tradewind
Riverside
11-01-2005, 10:17 AM
Use 1/8" soft copper tube. Much stronger that the original aluminum and you can get it at any plumbing supply store. You may have to visit an appliance repair place to get the break-away fitting for the bottom end, but the upper end is just a ferrule and nut. At least this worked for a Majic Chef out of a '68 Avion camper! Darol
11-01-2005, 01:32 PM
Child of the 60's
1965 17' Caravel
Bexley
, Ohio
Actually, it was the Kahiki and no they never rebuilt it . Talk about losing a slice of americanna!! There will never be another like it.
11-01-2005, 03:08 PM
1967 26' Overlander
Huntsville
, Alabama
Originally Posted by fun2bethad
Anyone know where I can find a 1/8 propane supply line (feeds the propane up to the top of the pilot light) for a Magic Chef out of a 65 Caravel? My supply line broke off at the back of the stove (probably from too much vibration)...
In what turned out to be a reasonable move, I replaced a similar line feeding the plilot light on my 1967 Bowen-Atwood water heater after one side of the line twisted off while removing it for another operation.
The only kit I could find, purchased at a local appliance parts house, contained enough plumbing to feed a pilot 36" away, and was really pricey ($30 or so). I think I was gouged a bit, but I have a soft spot for Mom & Pop operations.
More info available if needed.
Tom
11-02-2005, 09:20 AM
Child of the 60's
1965 17' Caravel
Bexley
, Ohio
Tom,
Thanks for the heads up. I'll start the hunt and see if I can get lucky
11-05-2005, 08:26 AM
Child of the 60's
1965 17' Caravel
Bexley
, Ohio
It just got uglier!
OK...so I go to remove the other side of the propane supply tube that is running up to the pilot light...and the entire threaded post just snaps off the pilot light assembly....ARGHHHHHH! So...now I am looking for all of the items in the photo below. Anyone have any good resource for an entire pilot light assembly out of a 65 Magic Chef (Model 160)?
11-06-2005, 11:15 PM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
OH oh !
I hate to be the bearer of bad news but that particular piece is obsolete. I did find one however, at an RV appliance shop. They have a decent inventory of NOS stuff. I don't think they have another one of those but you could give it a try. Here is the name of the place : Laurelhurst Heating and Cooling. They are located here in Portland, OR.
OR, you could go to an RV salvage yard and get a used one.
Keep looking you will find one someplace.
Chris
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
11-11-2005, 06:51 PM
1964 22' Safari
Foresthill
I'm also looking for gas lines for Magic Chef stove/oven. I need 1/8", 3/16" and 1/4". Originals are all aluminum tubing. I can't find anything but regular 1/4" copper tubing in Alaska. Any sources?
Walter
11-11-2005, 11:03 PM
2002 25' Safari
Dewey
Pilot Light, We don't need no stinken Pilot Light! Never use it. I have the adjuster turned off. Need to use the stove, pick up the lighter and click, it's on.
Richard
11-12-2005, 06:07 PM
Newcastle
, Oklahoma
You might try Associated Appliance in Oklahoma City. I found a new thermostat for my 67 Magic chef oven a couple of years ago. Did not think I would. They are very good at there trade. Their # 405-525-2003.
Barkingdogg Newcastle, OK
01-15-2006, 09:49 PM
colorado springs
Any luck yet?
I was just looking at this thread because my Magic chef model 880 is missing the same asembly. Just a couple of feeder tubes with broken couplers hanging off of them
If it helps, it use the be called the Pilot Assembly for a Harper 85 series Safety Control
You might be able to find someone to braze a new fitting on it.
01-16-2006, 11:22 PM
colorado springs
Is there a part # on that thing?
Just wondering if anyone had the part number for that pilot unit, so we know if we found what were looking for.
01-20-2006, 06:25 PM
Cumming
, Georgia
I was able to find stove parts at this website
http://www.partselect.com
If you have a model number for the stove or a stove thats similar lots of the parts are interchangeable with most of the changes being cosmetic for the different model numbers in a series.
I needed the little pilot light tubes for a four burner unit
this link shows an oven rack for the stove in my 79.
http://www.partselect.com/xq/aspx/In...m?SourceCode=3
if you scroll down you see tons of model numbers that use this same part. you can see diagrams for the various models if you click on a model link, then you should reach a ton of parts for that model, the parts have diagrams you can check for a visual.
They seem more geared towards major home appliances but they had the parts I needed to get cooking again safely.
Hope this helps.
Yes, This was my first post!
02-13-2006, 05:33 AM
colorado springs
looks like part number 5402H0202
I stumbled on this auction on ebay for a lot of 26 Harper-Wyman Pilots.
2 of them look like the piece where talking about, the 5402H0202.
http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
03-04-2006, 10:03 AM
1973 29' Ambassador
Troutville
, Virginia
universal kit
I found a universal aluminum supply line kit at a heating & airconditioning supply store - kit only had one 'breakoff' connector, but you can purchase the connectors separately Be sure to test for leaks - Jim J
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Magic chef Oven
Joyce K Glass |
Stoves, Ovens & Microwaves |
4 |
03-15-2008 11:34 AM |
Pilot light in Frig
niftypkg |
Refrigerators |
9 |
04-10-2005 12:04 PM |
Oven Thermostat
PeterH-350LE |
33 |
02-20-2003 09:39 AM |
Ref pilot
Dbraw |
Refrigerators |
2 |
08-27-2002 04:43 PM |
Furnace won't light /stay lit
Don |
Furnaces, Heaters, Fireplaces & Air Conditioning |
9 |
06-29-2002 03:37 AM |
