Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 12-10-2008, 07:30 PM   #1
Profile:  Currently Looking...
Zephyrhills , Florida
Magic Chef Oven doesn't function properly
I have a 72 century rv that is very similar to an Airstream. Inside I have a Magic Chef 4 burner stove top with oven below. The stove works great. The oven has issues. The oven burner will light but it will not stop at the set temperature, it just keeps rising. I realize that there was another post with a similar problem listed but i was unable to acquire any useful information from it. The range model number is 1370 A. Any help with this matter would be greatly appreciated.
adamnsari1 is offline   Reply With Quote
Old 12-10-2008, 08:43 PM   #2
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Pull the oven temp knob and see if there is an adjustment screw - either in the opening around the knob or down in the shaft that the knob came off of. You may be able to correct the problem with that adjustment only. Mine is down inside the shaft on a 71 wall mount.
GARY
OHIO - WE ARE THE MOTHER SHIP
Charter Member - NOVA
WBCCI - 5308
Old 12-10-2008, 09:57 PM   #3
It's not that the temperature setting is out of adjustment but that the main burner does not cycle off whatsoever.
Old 12-11-2008, 05:32 AM   #4
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Airstream Registry
Post
Here's a copy of the Magic Chef Guide that came with our 76. It has a troubleshooting section that be of some use.
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Old 12-11-2008, 07:18 AM   #5
Ganglin's Avatar
Gahanna , Ohio
Images: 13
I'm just giving you what the manual says for "run away' oven - the easy solutions/causes:
-foil lining the bottom or shelves in the oven
- gas selector not set to LPG
- adjust oven temp. regulator screw setting (refers you to the procedure)
- check for cracked capillary gas feed line
From there it gets more complex and involves replacing parts.
GARY
WBCCI - 5308
Old 12-11-2008, 09:26 AM   #6
alright, The manual was quite helpful but still I could not figure anything out. All of the gas lines are in great shape, tried adjusting the temp calibration but still no luck. Gas selector is properly set to LP. I did however read in the magic chef manual that was provided that there is a 45 second delay on the burner but is not the case with my oven. As soon as I turn the oven dial to 150 the burner kicks on and will stay on heating the oven beyond 400 degrees without any notion of cycling off. Could this be the temperature responsive unit or am I looking at getting a new thermostat control period? If this is the case, is there a way to dismantle the control itself to check for something stuck wide open maybe?
Old 12-11-2008, 09:43 AM   #7
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
The sensor element is probably kaput. If it's cracked you wouldn't necessarily be able to see it.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is online now   Reply With Quote
Old 12-11-2008, 10:10 AM   #8
Playa Del Rey , California
The thermostat control is broken. The "capillary" line to the temperature sensing bulb inside the oven has leaked out its fluid. Now the control is stuck open. It is either "full on" or "full off." The fix is a new control and, on a unit that old, probably requires disassembling a portion of the paneling.
VeniceLE is offline   Reply With Quote
Old 12-11-2008, 04:29 PM   #9
Tramp Streamer
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 65
Airstream Registry
Lightbulb The MAGIC is gone!
adamnsari1,
Sounds like the "Magic" portion of your Magic Chef oven has leaked out or somehow escaped. This is similar to letting the Jeanie out of the bottle and not all that uncommon.
Some owners report success with potions, incantations or amulets, but you should really just buy a new Jeanie.
If your stove is in otherwise good shape and just missing "Magic", you might want to consider replacing the temperature sensing bulb Witch comes with the "Magic" sealed inside the bulb. You just might save yourself a costly stove replacement.
Abracadabra
Michael
Click here Airstream Posters & Tee's
by Micheal Joseph Depraida
WBCCI No 8892 | VAC | KC2TQU
ArtStream is offline   Reply With Quote
Old 12-11-2008, 06:08 PM   #10
Update. Today I found a replacement thermostat unit at a local RV parts dealer and installed it. Funny thing, I still have the exact same problem. Wow. The oven just continues to heat no matter what the temperature setting. What now?
Old 12-12-2008, 12:57 AM   #11
Profile:  , Minnesota
Images: 59
Airstream Registry
I agree with the previous posters. I had the same overrun problem with my oven and I fixed it with a new thermostat and capillary tube.
No chance that the capillary tube in the new thermostat was bent or kinked? If it had been in stock for a long time, maybe it lost all its gas.
I ordered a fresh new unit and it works fine. It does overshoot about 25 degrees during preheat, then it settles down to +/- 10 degrees.
markdoane is online now   Reply With Quote
Old 07-07-2009, 04:24 AM   #12
fuselage's Avatar
Profile:
Where did you purchase the thermostat from?
fuselage is offline   Reply With Quote
Magic Chef Oven danesh Stoves, Ovens & Microwaves 34 03-31-2009 02:21 PM
Magic Chef Oven For Sale later Stoves, Ovens & Microwaves 9 10-30-2008 08:30 AM
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 11:34 AM
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 0 09-28-2007 07:45 PM
Magic Chef Oven Thermostat retrocowgirl Stoves, Ovens & Microwaves 1 09-17-2006 10:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
