Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 10-19-2009, 06:38 PM   #1
Sheridan's Avatar
Profile:  1965 17' Caravel
Mountainous , Utah
Magic Chef needs magic fix
Now I know why the oven in my 65 Caravel looked brand new, it probably hasn’t worked for decades. Because it’s in such great shape I’d like to clean it up and reuse it as the main cooking source in my total restoration. The problem is I discovered a broken part in the oven and I’m having a hard (read impossible) time finding a replacement. The pictures should explain the problem. I should be able to find a new line from the pilot fitting to the block with the pilot tubes but the deal breaker is that the fitting on the little cast block has been broken off (it was rusted solid when I tried to unscrew it).
Does anyone have this part?
Is there a replacement I could use for the pilot line?
Do I even need a pilot light? Can’t I just light the oven at the burner when I need it and turn the gas valve to the oven off when I’m not using it?
Dan
Sheridan is offline   Reply With Quote
Old 10-19-2009, 09:31 PM   #2
Sheridan's Avatar
Mountainous , Utah
WOW, not a single reply to this thread in three hours. Not even a " gee, that sucks for you".
Come on, I know someone out there has the perfect solution, a link to a Magic Chef parts warehouse, a Magic Chef they've replaced with a modern cook-top that could be parted out, something. Help!
Old 10-19-2009, 09:58 PM   #3
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
State of , Washington
Seridan- I'm sure you can find somone that is scrapping a mid 60's range and can send parts. I'd put it out on the airforums classifieds in the wanted section to. Sometimes things sit on the forums for days without a reply and suddenly the right reader comes along with solution. FWIW I'd much rather light a pilot light than reach a match into a semi-enclosed space with a full unlit gas burner on... I'd hold out for the right piece.
Scott & Megan
Visit our Blog- http://safari8671.blogspot.com
63 PARTS NEEDED
roof locker tracks (plastic)
square cornered astrodome screen
63 refer, or at least the original door insert
2 12v hehr motors (working) w/ or w/o fan blade
goransons is offline   Reply With Quote
Old 10-19-2009, 10:02 PM   #4
65Safari65's Avatar
Profile:  1965 22' Safari
Staunton , Virginia
You might be able to replace it with a similar part from a modern Magic Chef. The problem with not having a pilot light in there is that the main oven burner cycles on and off to maintain temperature, and needs the pilot for ignition.
Someone may correct me on this, but I would think that it isn't all that important to have the exact burner and pilot in the oven itself. Figure out what size fittings you have on there vs what's on the new stuff- it might be the same, and if not, you could cut it, and re-flare the pipe with the right size fittings for the new burner and pilot. A good hardware store can do all of that for you if you take the tubes for the burner and pilot out and bring them in to the store.
65Safari65 is offline   Reply With Quote
Old 10-20-2009, 12:17 AM   #5
Jim Foster
Jim Foster's Avatar
1983 27' Excella
Walnut Grove , California
Some propane suppliers have parts and material to do repairs. The guy in our little town does.
Old 10-20-2009, 12:52 AM   #6
Vallejo , California
I had the same problem a couple years ago. Luckily an RV shop in Napa had a pilot assembly in their stock of random parts that worked. I had the shop install it, so I would be no help in explaining how to do it.
My best guess is try to find a RV repair place that has been around a long time and might still have parts from the old days.
Stan Z is offline   Reply With Quote
Old 10-20-2009, 01:02 AM   #7
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
I'll check in the morning the parts that I pulled from our '66. I 'think' that our oven had the same problem as you have. I gutted the oven and installed a small microwave.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
Our Rig
Sept 2009
1966 Trade Wind
455 cid
Old 10-20-2009, 09:01 AM   #8
Sheridan's Avatar
Mountainous , Utah
Thank you all for your suggestions, I plan to follow your leads today and check with RV shops, Appliance Repair Centers, and posting on the forum for used parts.
Thanks again for your help.
Sheridan
Old Yesterday, 04:44 PM   #9
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
try this thread Free Magic Chef parts
I'm looking for the oven valve, the one with the knob, myself.
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Magic Chef for sale? air66stream Stoves, Ovens & Microwaves 15 05-28-2009 08:37 PM
Magic Chef Oven danesh Stoves, Ovens & Microwaves 34 03-31-2009 03:21 PM
Magic Chef Thermostat Brick Stoves, Ovens & Microwaves 8 03-23-2009 12:57 PM
Need help with an old Magic Chef oven bigjohn Stoves, Ovens & Microwaves 1 03-22-2009 09:07 PM
Magic Chef Stove Stone Ridge Stoves, Ovens & Microwaves 8 02-18-2009 08:15 AM
