Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 02-06-2007, 06:16 PM   #1
technautica's Avatar
Profile:
Magic Chef countertop range
Restoring "66 Overlander. I have replaced countertops and unfortunately cut hole for existing magic chef "model 34" drop in 3 burner range top. Mine is pretty rusted and I have priced out replating surfaces and it's pretty prohibitive. Has anyone found a source of parts for these old ranges or have one that has been removed for an updated installation? Burner box body is 13 1/2" x 31".
Does anyone make a new unit of this size?
Thanks for any help - James
technautica is offline   Reply With Quote
Old 02-07-2007, 12:43 PM   #2
Profile:  1968 26' Overlander
Clackamas , Oregon
James, I'm in the process of restoring a '65 tradewind with a similar problem. The surface should be steel, so you wouldn't replate, but have it polished. There is a place here in Portland called "Polishing by Tim" and he quoted my $60.00 to refinish mine. Go to the web, do a google on "refinishing steel" and you should be able to find someone local. Regards, David
pfefferd is offline   Reply With Quote
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 12:34 PM
HELP! I have busted the burner on my MAGIC CHEF! sequoiacoast Stoves, Ovens & Microwaves 11 07-24-2006 10:35 AM
parts for Magic Chef range aeriqua Stoves, Ovens & Microwaves 1 01-09-2006 07:26 AM
Magic Chef oven won't light, revisited Safari64 Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-23-2005 07:14 PM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
