Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 10-30-2009, 10:10 PM   #1
mddsmith's Avatar
Profile:  2002 27' Safari
Arlington , Texas
Magic Chef blast furnace
We just bought our first Airstream and got it home a few days ago. It's a 2002 Safari 27. We can't wait to get it on the road. We've been checking all the systems, and the oven has thrown us for a loop. Lighting the pilot went just like the book said, but then when I turned the knob to get the main burner going a really big, billowing flame pushed out from under the shelf that's just above the burner. And this was with the knob just turned to "warm." When I turned it up to 250 and above, it got even worse. The flame made an instant sooty deposit on the bottom of the shelf and on the door when I closed it. Also, the book says that when you turn the knob there should be a delay of up to 45 seconds before the main burner comes on. With ours, there was an instant flame-up as soon as the knob was turned. I have not checked the gas pressure, but if it means anything, the top burners, the furnace, and the water heater all seem to be working perfectly. After reading some of the other threads, I did find the adjusting screw that's behind the oven knob and managed to reduce the flow of gas. However, this only seems to delay the problem until a higher temperature is dialed in on the knob. Right now when I turn the knob I have nothing but pilot light until I get to about 300, then the big flame kicks in. Any suggestions would be appreciated.
mddsmith is offline   Reply With Quote
Old 10-30-2009, 10:31 PM   #2
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Airstream Registry
Maybe, maybe not.
Hi, I have read that on some ovens, the gas tube from the control valve to the oven burner has cracked or broken completely off. I would check for this situation before going any further. Could be dangerous. I personally haven't had this problem, But keep it in mind if it ever happens on my trailer's oven.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 10-31-2009, 12:40 AM   #3
aluminauti
whitelight's Avatar
Profile:  Where we , Park it!
Blast = bad!
Whenever I hear blast associated with a propane appliance, it gives me cause for pause.
Did you receive an AS owner's manual/gray (aluminum) color binder? There should be a Magic Chef manual in this binder that provides service contact information for Magic Chef. Contact them with the stove model number & explain the problem - never know, there may be a warranty recall issue.
Whatever you do, best to get someone in the know to take a look at the problem. Several years ago, we attended an AS rally where one of the trailers was experiencing a similar problem with their Magic Chef oven; they too had been attempting to adjust the flame. One evening, we were gathered outside their trailer for a small pot-luck, sitting around munching on appetizers & sipping wine. Suddenly, we heard a "whoosh" punctuated by a shriek - our host emerged from his trailer with wide eyes, singed hair & missing his eyebrows. When lighting the oven to cook his evening's contribution to the meal, his oven flamed up & blasted out at him.
When it comes to malfunctioning propane appliances, especially ones that blast, it's probably prudent to have someone in the know inspect & diagnose the problem.
whitelight is offline   Reply With Quote
Old 10-31-2009, 08:17 PM   #4
mddsmith's Avatar
Arlington , Texas
Thanks for the replies. This morning we decided to drop the AS off at a local repair shop to have this problem checked out. I don't mind doing a few light repairs myself, but this is one we decided to leave to a professional.
Old 10-31-2009, 08:23 PM   #5
aluminauti
whitelight's Avatar
Thumbs up Good Call!
We, like you, prefer to do as many repairs ourselves. However, there are some things best left to the pros!
Keep us posted as to the final diagnosis.
Old 10-31-2009, 10:40 PM   #6
DaveFL's Avatar
Profile:  2000 Land Yacht 30(31') , Inverness, between the Withlachochee River and the Gulf of Mexico, Fl
Sounds like a leak to me, lucky to find it without disaster. Have the professional show you how it lights before you leave the shop.
DaveFL is online now   Reply With Quote
Old 11-01-2009, 06:26 AM   #7
tinbender's Avatar
Profile:  2001 16' Bambi
1972 23' Safari
Piedmont Region , North Carolina
Blast Furnace
mddsmithMagic Chef blast furnace
Had the same problem in my oven. Photo shows the culprit. Broken gas line. I called Magic Chef, part is readily available. New line came with connectors on both ends, easy installation.
TB
tinbender is offline   Reply With Quote
Old 11-01-2009, 08:18 AM   #8
mddsmith's Avatar
Arlington , Texas
Tinbender, I think you hit the nail on the head! That looks exactly like what I'm seeing. And your photo is a good illustration of what ROBERTSUNRUS was talking about. I'm going to wait and see what price the repair guy quotes me. If it sounds reasonable, I'll let him do it. That way I can relax and know it's done correctly. If it sounds high, or if he tells me I need a whole new stove, I'll follow your example and tackle it myself, even though it might place my eyebrows in peril!
Old 11-01-2009, 02:06 PM   #9
DaveFL's Avatar
Originally Posted by mddsmith View Post
Tinbender, tackle it myself, even though it might place my eyebrows in peril!
Don't turn it on with a lit cigarette
With gas off at tank, no danger, as soon as you turn on gas, check all lines with soapy water, turn on burners first to bring gas to stove, check for leaks at worked area and then try stove. Eyebrows would be minor compared to the potential gas can do.
Old 12-07-2009, 10:24 PM   #10
Profile:  2003 25' Safari
West Vancover , B C
I have the same problem. How do I find out whether anything is being done about a recall?
hiljon is offline   Reply With Quote
Old 12-08-2009, 07:19 AM   #11
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
I also found this problem on an ORIGINAL install Magic Chef in a 1964 GT trailer. The gas line breaks from vibration. Also, the gas line is very short and is in a tight location.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Magic Chef needs magic fix Sheridan Stoves, Ovens & Microwaves 8 11-21-2009 03:44 PM
Magic Chef for sale? air66stream Stoves, Ovens & Microwaves 15 05-28-2009 07:37 PM
Need help with an old Magic Chef oven bigjohn Stoves, Ovens & Microwaves 1 03-22-2009 08:07 PM
Magic Chef Stove Stone Ridge Stoves, Ovens & Microwaves 8 02-18-2009 07:15 AM
Magic Chef Stove Tin Lizzy Stoves, Ovens & Microwaves 2 06-20-2006 02:20 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
