Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 11-18-2018, 02:31 PM   #1
Evergreen , Colorado
Lighting Pilot on 1966 Overlander Magic Chef Oven
Can't figure out how to light the pilot on the oven. I've tried holding down the pilot knob while holding a stick lighter to the pilot for an extended amount of time. Have a 50s stove in the house that lights up no problem. This looks like it should function the same but nothing is happening. The gas is for sure on as I lit the stove and fridge just fine. Totally stumped.
ID:	328122   Click image for larger version
caitlyn567 is offline   Reply With Quote
Old 11-18-2018, 08:49 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
1966 Overlander Magic Chef Oven Pilot Light
Greetings caitlyn567!
Welcome to the Forums and the world of Vintage Airstreams!
While I can't be absolutely certain since your range/oven is newer than mine, but it wasn't uncommon during that time period for a gas control valve for the oven/pilot to be located under the cover for the range top. You may need to remove the burner grates, then lift the hinged top -- there you may find as many as two valves -- one may be for the stove-top pilot light while the other may be for the oven pilot light. Hopefully this may help, but they may have changed this feature by 1966.
Good luck with your Overlander!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 11-22-2018, 12:07 PM   #3
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
lighting oven pilot
set the temp control on 300
set the pilot control to pilot
there are 2 pilot lights
if they dont light they are probably stopped up
I am dealing with that on one of my pilots now....follow the little gas lines to their end and that is where the pilot is
mkcurtiss is offline   Reply With Quote
Oven pilot light problem, '79 Magic Chef blickcd Stoves, Ovens & Microwaves 10 09-28-2013 12:31 PM
Magic Chef oven pilot lighting falcon-N-Air Our Community 23 06-03-2013 10:45 AM
Magic Chef Oven Pilot flames/blows out HansenClan LP Gas, Piping, Tanks & Regulators 3 09-22-2008 10:28 PM
Looking for pictures of early 60's Magic Chef oven Pilot assembly volvophile Stoves, Ovens & Microwaves 9 07-04-2007 05:33 PM
Magic Chef Oven pilot sammamishsafari Stoves, Ovens & Microwaves 2 08-22-2003 08:17 PM
