Old 01-24-2012, 01:30 PM   #1
1992 25' Excella
berkeley , California
Knobs for a Magic Chef range-'92 Excella
Hi- we're refurbishing a 25 foot '92 Excella and all of the knobs on the range are missing, and the plate with the model numbers is also gone, so we can't find the model number needed to even look for parts-- Does anyone know what model number this range is??
excellanancy is offline   Reply With Quote
Old 01-24-2012, 02:45 PM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
We have an 89 excella and the range is original and we have all of the paper work for it. Do you want to post a photo of yours? We are happy to help if they match!
Skatiero is offline   Reply With Quote
Old 01-24-2012, 07:12 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If your not able to find originals - these will make a suitable replacement:
RV Gas Burner Knobs - PPL Motor Homes
You should also find these at Lowe's and HD....
Old 01-25-2012, 11:24 AM   #4
1992 25' Excella
Thanks for knob info
Thanks!! I will try to post a photo- it would be great if I could get the model number, etc! And thanks for the link, too....
Old 01-25-2012, 11:29 AM   #5
1992 25' Excella
[IMG]file:///Users/nancyisaksen/Desktop/IMG_2556.JPG[/IMG] Here is the Magic Chef in the '92 Excella (first try at a photo...)
Old 01-25-2012, 11:52 AM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Nancy, you'll need to take a different approach to your photo. Here is a link to the FAQ on adding attachments to your post:
Airstream Forums - FAQ: Reading and Posting Messages
Lynn
WBCCI 21043
Old 01-25-2012, 03:51 PM   #7
1992 25' Excella
Magic chef in "92 Excella
Here is the photo, I hope-- "Take Two"--(Thanks, Lynn)
Old 01-25-2012, 05:19 PM   #8
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Our 88 Excella has similar Magic Chef, only with different grids on top.. There are phone numbers for service parts, but first step is to ID Stove Modle Number.. It is on data plate under top panel of stove and on side of unit.. Try removing grid bars and then lifting up sheet metal top of stove, and look on sides for ID info.
From there, you can call Magic Chef parts in Indiana for "Top Burner Knobs" and "Thermostat (Oven Control) Knob" that are a match for your stove...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 01-25-2012, 05:56 PM   #9
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Our stove looks the same and we also have a '92. We store the trailer off-site and I plan to do some maintenance soon so I'll check our model numbers, etc. and get back to you.
Contacting Magic Chef directly is a good idea and they may be able to help. Otherwise a good local appliance parts dealer may be able to help. I've found a surprising number of parts at Fox Appliance Parts and I think they'll ship anywhere. I've kept washers, dryers, stoves and other appliances running with parts from Fox long after most service personnel indicate the units are obsolete.
Lucius
nvestysly is online now   Reply With Quote
Old 01-25-2012, 06:33 PM   #10
1992 25' Excella
I'll look forward to hearing from Lucius and Skatiero for possible model numbers- thanks so much. And for the name of the appliance parts dealer. As for finding the model numbers under the top of the stove-- the numbers seem to be truly gone-- and I have already called Magic chef, and talked to several people, but they said that without the model number-- zip.....thanks for the ideas.
Old 01-25-2012, 09:30 PM   #11
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I will look tomorrow after school!
Old 01-26-2012, 05:27 PM   #12
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
The label on our stove indicated when you call for parts be sure to include the model number and the specification number. From what I can tell the model number is BT22RS and the specification number is 4TVX. It was listed on the label as BT22RS-4TVX.
The serial number on ours is 11C136731530 but I suspect that won't help you.
Good Luck!
Lucius
Old 01-26-2012, 06:29 PM   #13
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Our model number is BT22NA-4TVX. Our serial is 02C833766393. I am going to upload a photo.
Old 01-26-2012, 06:33 PM   #14
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
My husband took the photo mostly of the knobs!
Vintage Magic Chef Oven Operation Primer TouringDan Stoves, Ovens & Microwaves 28 11-03-2016 07:15 AM
Looking for 3 grates: Magic Chef Model #165 Merlita Stoves, Ovens & Microwaves 11 01-25-2015 09:35 AM
Does Magic Chef still make replacement parts? flon2205 Stoves, Ovens & Microwaves 11 01-14-2012 09:01 PM
Please Help! Magic Chef Countertop stove low flow blazeff13 LP Gas, Piping, Tanks & Regulators 4 08-26-2011 09:55 PM
Magic chef oven cathy72417 Stoves, Ovens & Microwaves 0 08-05-2011 07:56 AM
