Kitchen Exhaust Fan Questions
Resealed outside exhaust vent. First the fan worked, then didn't, then did and now doesn't. Think the problem is the micro limit switch. Can I disconnect one of the two wires and touch it to the other wire to see if this is the problem? Can hear it click when lever is depressed.
The outside vent cover has new stainless steel screws and resealed. There is a round gasket on the inside of the vent cover that appears to be entact. Any need to replace this? If so, what does one use? Thanks again for all your help. Jack
