Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 09-27-2005, 03:43 PM   #1
Child of the 60's
Profile:  1965 17' Caravel
1984 31' Sovereign
Bexley , Ohio
Is the stove supposed to light at hole on back wall?
I just bought a new Caravel and was testing out the utilities. I turned on one propane tank, lit a burner (which lit just fine) but when I went to light the pilot for the stove, a hole in the back of the stove (where the propane comes in from?) lit up instead. Didn't look right to me so I shut the whole thing down and vowed to have it looked at. What do you think? Did I just light it wrong?
fun2bethad is offline   Reply With Quote
Old 09-27-2005, 03:56 PM   #2
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Not good
Sounds like a loose fitting or a punctured gas line on the gas supply.
The pilot is usually about 2/3 the way back from the front of the oven and centered right to left. The pilot flame is fairly small and can sometimes be hard to see in bright light.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 09-27-2005, 05:09 PM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
I had that issue with a water heater pilot. It turned out the feed line for the pilot was cracked at the fitting, and had to be replaced.
You did well to shut it down until you can get it looked at, let us know what you find out.
(No Longer at Inland RV)
Old 09-27-2005, 10:24 PM   #4
Child of the 60's
1984 31' Sovereign
Bexley , Ohio
Red face Cracked Propane Line?
Indeed I shall have it inspected by a professional. This seems like the most intelligent direction to take since it is new to me and I don't have any history with it yet. Thanks for the input!!
Old 10-24-2005, 07:11 PM   #5
Child of the 60's
1984 31' Sovereign
Bexley , Ohio
Figured out the issue...
Indeed the gas feed from the back of the stove to the burner unit was cracked at the fitting. I've removed the fitting but I've no idea where to find a replacement. It's a Magic Chef so I guess I'll hit the net and see what appears.
Old 11-07-2005, 10:24 PM   #6
Profile:  1990 34' Excella
Windcrest , Texas
Replacing the stove
Hey everyone we're still plugging along on our new AS and finally got around to updating the countertop and stove. The AS had the original 1975 Magic Chef which was beyond cleaning. I also didn't trust it, so we went to the local AS dealer to see what was going on (Alamo RV here in San Antonio). Anyway, some new AS owners had asked the dealer to remove the stove and put in a cooktop with a microwave in the area initially taken up by the oven.
Hence, our new stove/range cost me $200 . Not bad for a stainless steel model. While we were at it, I went ahead and had a new countertop built for $150 and put that in myself. Enjoy the photo's.
PS. Here are the before and after photos.
Mitch
ID:	16122   Click image for larger version
Swanny is offline   Reply With Quote
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 09:52 AM
Ouch! What happens when an Argosy MH meets the back of a dump truck 66TradeWind Airstream Motorhome Forums 13 08-12-2002 03:49 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 11:51 PM
