Old 10-03-2017, 05:57 PM   #1
S/O#080
Tschupp's Avatar
2006 30' Classic S/O
Tucson , Arizona
Induction Cooktop
Just bought a Classic 2006 with s/o. I want to replace my gas stove top with a two burner induction cooktop. Has anyone done this. If so, happy with results?
Tschupp is offline   Reply With Quote
Old 10-03-2017, 06:41 PM   #2
2014 30' Flying Cloud
Ponce Inlet , Florida
We put in a Truinduction cooktop over a year ago. Love it! Had to replace the countertop because of the difference in size between the gas and the induction.
ID:	296157   Click image for larger version
bunni is offline   Reply With Quote
Old 10-04-2017, 09:02 AM   #3
Hubbie just told me they make a slightly smaller model now. And you might not have to replace the counter.
Old 10-04-2017, 09:30 AM   #4
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
How many amps do these draw?
dmbecke is offline   Reply With Quote
Old 10-04-2017, 09:57 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
That's the gotcha.
You pick the power output when you shop for the stove top. More cooking heat means more electrical draw. The stock answer is - more than you want to run off of the standard batteries, less than what matters on shore power. I believe the one shown pulls 1,800W (so full load = 15A, wire it to a 20A breaker).
Old 10-04-2017, 05:55 PM   #6
Bunni's DH here,
The induction cooktop pulls 1800 watts at full power. We rarely use full power except to boil water.
I use the microwave circuit for power. That limits you to using one at a time. I have a work around using a 20Amp rated extension cord. We have only used it a couple of times. It ain't purdy but it works.
You do need to think about batteries/generator if you plan to boondock.
If you plan to boondock with the factory batteries and no generator this is probably a less than ideal set up.
We have 600 AH lithium battery bank and solar. It allows us to boondock for 3-4 days in crappy weather with a little energy conservation. A generator would also work as well.
Beach Bum is offline   Reply With Quote
Old 10-14-2017, 09:54 AM   #7
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Go with a portable induction cook top Salton single as we have or double . What I like about them is you can tune your power to cook in Watts or Temp . So you can actually draw down to 800 watts . Also note I have changed out the starter on the gas cook top to electronic, that is a cheap and good mod. Sorry pic is on its side .
BTW Bunni nice layout
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
Laurence
LAWBC is offline   Reply With Quote
Old 10-14-2017, 03:17 PM   #8
The portable is a great idea. We used one for a year before we put in the countertop model. I'm short and using the portable on top of the gas stove -- We used a wooden cutting board type thing on top of the stove -- was a little high for me. We still use the portable to cook outside.
Induction Cooking dghaas Stella's Kitchen 9 11-02-2016 08:34 PM
Induction cooktop? shermantic Electrical - Systems, Generators, Batteries & Solar 9 12-28-2015 12:27 PM
Portable Induction Cooktop urnmor Stella's Kitchen 17 01-11-2015 11:47 AM
Induction Cooktop BAB Stoves, Ovens & Microwaves 22 01-13-2014 10:30 PM
Ceramic/Induction Cooker Top/Hob degs123 Stoves, Ovens & Microwaves 2 04-25-2010 03:15 PM
