Old 04-29-2017, 12:10 PM   #1
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
Igniters on Atwood stove not working
The igniters on my Atwood stove are not lighting the burners. They light fine with a lighter so no propane issues there. Anybody have this crop up with a new trailer? I have a 25' 2016 flying cloud.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 04-30-2017, 12:42 AM   #2
Mattirs's Avatar
Fairfield , California
Ours is hit and miss on one of the burners, the others work fine.
Mattirs is offline   Reply With Quote
Old 04-30-2017, 05:59 AM   #3
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
check the fuses
rbs is offline   Reply With Quote
Old 04-30-2017, 06:26 AM   #4
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
We have the same issue, the back two burners work fine and the front burner works sometime. The front burner is fine if we use a ignitor so I know that we have gas
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
Ponyfvr is offline   Reply With Quote
Old 04-30-2017, 08:21 AM   #5
brokeboater's Avatar
High Springs , Florida
Originally Posted by rbs View Post
check the fuses
Where would one find the igniter fuse?
brokeboater is offline   Reply With Quote
Old 04-30-2017, 10:32 AM   #6
Mollysdad's Avatar
I found it easier to just keep a long neck flame thingy in the overhead cabinet. Yeah, the sparker worked about half the time, but IIRC, the spark is created by hitting a crystal with a hammer. (Piezo). The flame was faster, and worked 100% of the time.
Old 04-30-2017, 12:19 PM   #7
jackson center , Ohio
Igniters
Have you lifted the burner plate and checked if all the igniter wires are connected at the burners and also at ingniter knob?
Schu is offline   Reply With Quote
Old 04-30-2017, 01:00 PM   #8
2002 19' Bambi
Lafayette , California
Not surprisingly, Schu has it right. The wires between the igniter knob and the burners seem to have a will of their own. They can come loose for what seems like absolutely no reason.
Tim
Tim A. is offline   Reply With Quote
Old 04-30-2017, 01:07 PM   #9
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
It's a flaky design. Just about everybody has problems with the lighters. The wires between the ignitor and burners easily short. I ran mine through that cheap 1/2" split electrical conduit to help stop shorting.
kscherzi is offline   Reply With Quote
Old 04-30-2017, 06:28 PM   #10
Friday Harbor , Washington
SAME issue as Kscherzi
My 25 FC 2016 stove had the same problem as Kscherzi, as well as not all the burners lighting evenly, even after I discovered a loose wire.
Rob Cope is offline   Reply With Quote
Old 04-30-2017, 07:46 PM   #11
2014 16' Sport
Newport Beach , California
Atwood igniters
One of mine wasn't sparking. It's easy to overthink the problem. I took an old toothbrush and dipped it into alcohol and brushed the accumulated crud off and it worked fine. Simple solution.
CalifBob is offline   Reply With Quote
Old 04-30-2017, 08:00 PM   #12
2014 23' FB Flying Cloud
Albany , Oregon
Unhappy The burners work fine...but...
...we can't keep the pilot light to remain burning in the oven of our Atwood range/oven - I don't think the oven has ever been used (2014 23' FC).
Hence, no biscuits in the morning or cookies later on in the day.
Ideas or suggestions?
Oregonyoung is offline   Reply With Quote
Old 04-30-2017, 09:31 PM   #13
1986 31' Sovereign
Miami , Florida
Are you holding the valve in for a solid 30 seconds before attempting to light it?
If it doesn't light at that point, rotate the knob to, say 350, and the burner should fire up.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-01-2017, 12:41 AM   #14
Mattirs's Avatar
Just spoke with my wife says same problem, back two work fine, front one doesn't.
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Lights Not working in hood over stove PSU1981 General Repair Forum 18 02-12-2016 01:53 PM
Atwood 6 gal water heater not working Barefootdog Water Heaters, Filters & Pumps 9 01-22-2015 11:43 PM
Atwood DSI not working erock53 Water Heaters, Filters & Pumps 3 06-06-2011 08:06 AM
Trailer Atwood Water Heater not working? silverback Water Heaters, Filters & Pumps 2 06-01-2010 09:52 AM
