Old 05-01-2017, 05:57 AM   #15
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
the fuse for my ignitors was also for the antenna booster, and the power awning, so something is also on the fuse, and of course would not be working. All of our ignitors work just like they are supposed to
rbs is offline   Reply With Quote
Old 05-01-2017, 06:31 AM   #16
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Fused ignitors? Mine have always been piezo electric - no power needed. And the oven has to be lit each time, there is no constant pilot, once you turn off the oven.
If you mean that it doesn't remain lit while the oven is on and is cycling, then you probably need a new thermocouple, an easy fix.
2012 Dodge Durango Hemi/AWD
Old 05-01-2017, 09:10 AM   #17
2014 23' FB Flying Cloud
Albany , Oregon
Correct...pilot won't remain lit to even get the oven burner to light. I'll try the thermocouple idea. Thanks!
Oregonyoung is offline   Reply With Quote
Old 05-01-2017, 09:45 AM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by kscherzi View Post
It's a flaky design. Just about everybody has problems with the lighters. The wires between the ignitor and burners easily short. I ran mine through that cheap 1/2" split electrical conduit to help stop shorting.
What he said.
I removed the wiring to the igniters and slipped a slightly larger heat shrink tubing onto the wires and re-installed.
Problem solved.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-01-2017, 10:47 AM   #19
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
http://www.airforums.com/forums/f44/...-138362-2.html
"Chip Tank" is in Paso Robles Ca.
CDONA is offline   Reply With Quote
Old 05-02-2017, 07:57 AM   #20
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
my 2015 has electronic ignitors, our 04 had the "old" style piezo
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Lights Not working in hood over stove PSU1981 General Repair Forum 18 02-12-2016 01:53 PM
Atwood 6 gal water heater not working Barefootdog Water Heaters, Filters & Pumps 9 01-22-2015 11:43 PM
Atwood DSI not working erock53 Water Heaters, Filters & Pumps 3 06-06-2011 08:06 AM
Trailer Atwood Water Heater not working? silverback Water Heaters, Filters & Pumps 2 06-01-2010 09:52 AM
