Old 10-23-2011, 08:09 PM   #1
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
How To: Replace Convection-Microwave w/ Gas Range
I have just completed the replacement of my Convection-Microwave and gas Cooktop with a gas Range. We prefer to use a regular oven to the convection-microwave oven, so after the recent purchase of our '05 30' Classic, we took on the project to perform this replacement.
Here are the before and after shots. It actually came out quite well. In the subsequent posts, I will show the process.
ID:	143535   Click image for larger version
10Smiles is offline   Reply With Quote
Old 10-23-2011, 08:13 PM   #2
10Smiles's Avatar
2005 30' Classic
Removal of the Gas Cooktop
The first step was to remove the drawers, the Convection-Microwave Oven, and the gas Cooktop...
ID:	143537   Click image for larger version
ID:	143539   Click image for larger version
Old 10-23-2011, 08:16 PM   #3
10Smiles's Avatar
2005 30' Classic
Install New Range
Next, the new Range is installed after removal of the drawer divider cabinet parts...
ID:	143541   Click image for larger version
Old 10-23-2011, 08:23 PM   #4
10Smiles's Avatar
2005 30' Classic
Cabinet Work for the Drawers
The opening where the Convection-Microwave oven was is close to correct, but not quite. It is not quite tall enough, and it is a bit wider than needed. So, I had to cut the opening a bit bigger by cutting out the wood at the bottom of the opening. This made the height just about right. Then I installed new drawer divider cabinetry (after having to order hickory wood on-line) and shimmed the sides a quarter inch narrower on each side. I finished the new woodwork. Then I installed the drawer slides.
ID:	143544   Click image for larger version
Old 10-23-2011, 08:27 PM   #5
10Smiles's Avatar
2005 30' Classic
The Finished Project...
Another picture of the finished project.
This actually took me a couple of months to complete with ordering the Range, getting the hickory wood, and measuring many times to see if it would actually work.
I would like to take the time to thank the Air Forums contributors for all the help I have received in recent months. Maybe this will help some others.
David
Old 10-23-2011, 08:31 PM   #6
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Looks awesome!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Old 10-23-2011, 08:32 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Looks great!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 10-23-2011, 09:39 PM   #8
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Great job.. looks like a nice installation. We removed out cooktop and installed the oven too as we like having that vs. the use of that convection oven. The next step for us is to remove the convection oven which is mounted opposite the regular oven and just install a regular microwave. The display panel is out again after having it repaired and it takes a rocket scientist to figure it out anyways..
Here is our link.
http://www.airforums.com/forums/f426...ons-51901.html
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 10-23-2011, 10:29 PM   #9
cptfish's Avatar
2014 27' FB International
salem , Oregon
I want to do the same thing to our 25' Flying Cloud. Wondering why you flipped the drawers with the oven space?
cptfish is offline   Reply With Quote
Old 10-24-2011, 06:21 AM   #10
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Very nice work. We have considered doing just the opposite. You made the changes look easy.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-24-2011, 12:38 PM   #11
10Smiles's Avatar
2005 30' Classic
I thought about purchasing just an in-wall oven to replace the convection-microwave. I did a bit of research, but couldn't find one that didn't require 120VAC for the control circuitry.
So, I decided to replace the cooktop with the range/oven combination. This was a relatively easy swap since the space is used for that from the factory when a gas oven is installed. Then I "just" had to move the drawers over (easier said than done).
Old 10-24-2011, 12:40 PM   #12
10Smiles's Avatar
2005 30' Classic
Regards,
Easy, aye! It wasn't too hard, just had to be careful. I made a couple of mistakes that, if I had to do it over again, I would do differently.
Old 10-31-2011, 12:04 AM   #13
Elf1's Avatar
1990 34' Limited
Proud to be , an American
David,
Care to share the "do over" wish list......??
I for one like to create shorter learning curves in those ares by not feeling the pain directly ;-)))
Cheers
Elf 1
Elf1 is offline   Reply With Quote
Old 11-07-2011, 07:58 PM   #14
10Smiles's Avatar
2005 30' Classic
Originally Posted by Elf1 View Post
David,
Cheers
Elf 1
A couple of things...
1) Make sure you cut the boards the correct size that go between the drawers. I cut mine about an 8th of an inch too big (tall), so the drawers would not fit with the slides in. I had to notch the slides into the rail below. It wasn't too big a problem, but was anoying.
2) I had to add plywood to the back of the cabinet for the back of the drawer slides to attach to. I didn't make the one on the right tall enough for all screws. So, the top drawer slide on the right has only one screw attaching it to the back. I will probably add to the plywood to get the three screws in.
Other than that, it went quite well. As with all projects, you have to go with the flow and make adjustments along the way.
Regards,
David
convection microwave oven surfsup Electronics & Connectivity 17 04-20-2014 08:04 AM
Replace stove with stovetop and microwave convection oven dorisbranch Stoves, Ovens & Microwaves 15 10-21-2011 10:07 AM
Gas Oven to Replace Convection/Microwave 10Smiles Stoves, Ovens & Microwaves 7 08-26-2011 08:52 PM
No Gas to range cuyd Stoves, Ovens & Microwaves 22 06-27-2011 07:09 PM
Locking Down the Microwave Road Geezer General Appliance Topics 5 05-27-2011 10:36 AM
