Old 03-30-2010, 09:44 AM   #1
MTsafari's Avatar
1970 23' Safari
Columbia Falls , Montana
How to light the oven?
I have Magic Chef stove/oven, which is original to our 1970 safari, and in good shape, really clean. The stove is operational, but I have never tried the oven. Frankly, I'm scared of it, and do not know how to light it or use it.
I have no documentation, of course, that provides step-by-step instructions.
Any advise on how to light it, see if it works, and if it is safe?
Name:	232323232%7Ffp349)nu=3243)249)9;;)WSNRCG=3234 447 3(77nu0mrj.jpg
MTsafari is offline   Reply With Quote
Old 03-30-2010, 10:08 AM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Can't speak to whether it is safe or not. However lighting it is a two-step operation.
First, turn the oven knob to "pilot". This allows a very little amount of gas to the pilot assembly, located under the gray shelf. There is a small arm that comes toward you at about a 45 degree angle.
Hold your match-type lighter over the end of that piece. You should see a small pilot light after a moment or so.
Next, turn your oven knob to your desired temp - say, 350 degrees. It will take a few moments for the pilot to heat the capillary tube (which will permit oven gas to flow) and then you will see the oven flame surround the whole burner.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 03-30-2010, 10:22 AM   #3
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
On the older models of the stove, there was a safety valve that has to be opened. It is located under the stovetop.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 03-30-2010, 11:28 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
In the RV stoves we've had, the pilot is located at the rear of the burner, near the back of the stove. Not always the easiest thing to locate exactly where to put the match flame. But safe enough to light, since the amount of gas flowing in the pilot postion is pretty small.
Chris
Old 03-30-2010, 12:03 PM   #5
68Safari22
1968 22' Safari
edmond , Oklahoma
I have a 1968 with a Magic Chef that looks like the one in the photo. Mine does not have a "pilot" position on the thermostat. To light the pilot I have found it easiest to remove the porcelin shelf that forms the bottom of the oven. It is the shelf just above the burner. Then you can clearly see the pilot at the rear of the burner. You don't have to press any button, but you might have to turn on the pilot. On mine there is a small thumb valve located in the stovetop. There is a pipe or manifold that carries the gas to the top burners and the oven. Next to the thermostat is a valve that you can open, if it is not already open, with finger pressure or a blade screw driver. Then of course apply a flame to the pilot in the oven. It should burn high enough to stay lit, but not have a red tip.
After replacing the shelf, be sure to test the temperature of the oven with a thermometer. Mine is off 75 degrees. I checked at 250, 300, and 350 and it keeps the temperature 75 degrees higher than that. No problem though, I just subtract 75 from whatever temp the recipe calls for and the oven works fine.
Harleyyat is offline   Reply With Quote
Old 03-30-2010, 01:07 PM   #6
2008 28' Safari SE
winter garden , Florida
step 1. close the oven door
step 2. close and lock the trailer door
step 3. go to your favorite place to eat
repeat these steps whenever you feel the need to lite your oven.
bob34787 is offline   Reply With Quote
Old 03-30-2010, 02:57 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Do you have pilot position on the knob? Also, look at the knob closely and see if you see a small dot near the 500 degree mark. If so it's should be like the 71.
Light the pilot and let it burn a minute or two. Then turn the oven up past the dot (or 500 degree mark). The oven should light - yes it's a little loud. Then turn it down to desired cooking temp..
If the temp. is off - pull the oven knob and see if there are one or two screws. One may be inside the shaft. If it has those we can get you the adjustment procedures.
Old 07-15-2010, 04:06 PM   #8
1983 34' Excella
Cloudcroft , New Mexico
Mine has the little slot in the shaft of the knob. I was able to lite the small pilot and at times I could get the main burner lit, but after a few seconds it would go out. What does the little slot control?
johnfarrow is offline   Reply With Quote
Old 07-15-2010, 05:01 PM   #9
r carl's Avatar
Lin , Ne
That valve under the stovetop on my 1985 magic chef is to turn on the gas for the pilot for the 4 stovetop burners.
Old 07-15-2010, 07:31 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
If it goes out after a few minutes you probably have a bad thermocouple.
The slot controls calibration of the temperature dial and can be used to compensate for consistent errors, like the off-by-75 degrees one mentioned upthread.
Old 07-19-2010, 01:24 PM   #11
1965 24' Tradewind
Nicholasville , Kentucky
My 1965 Tradewind has a magic chef and the knob does not have a slot marked "pilot" But I have the manual and it reads to turn the knob to 300 degrees and you can depress it and hold it down to light the pilot. That pilot stays on and is supposed to light the second pilot (which does not seem to work in my stove) Let me know if anyone figures that out.
Dr Dan is offline   Reply With Quote
Old 07-19-2010, 02:46 PM   #12
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
On our stove you have to hold the match or lighter you are using ON the tip on the little arm that the pilot light at the end of for a few seconds. The thermocouple has to heat up (and open) before the pilot will actually light.
Maybe you need to be more patient? Or.. there could be other things wrong. Try reading here for some tips http://www.airforums.com/forums/f426...hef-52993.html
AirForums Custom Search
Janet H is offline   Reply With Quote
Oven pilot light problem, '79 Magic Chef blickcd Stoves, Ovens & Microwaves 10 09-28-2013 12:31 PM
2006 Safari SE - Oven won't light dbradhstream Stoves, Ovens & Microwaves 22 11-14-2011 04:40 PM
What type of light bulb for oven? kimbal88 Stoves, Ovens & Microwaves 1 04-10-2007 08:16 AM
Magic Chef oven won't light, revisited Safari64 Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-23-2005 06:14 PM
Oven won't light jyobp Stoves, Ovens & Microwaves 9 04-19-2004 07:01 PM
