Old 08-26-2017, 04:33 PM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
How do modern RV Ovens Work?
I just completed a repair on my '67 Overlander's oven with nothing but labor that should keep us in bacon, biscuit, and anything else we want to bake on our next trip.
The oven's current issue had me thinking a replacement would be in order. But no one sells just an oven anymore - they only sell ranges with burners on the top. I'm thankful for small favors.
Since the innards of my oven are in good shape, I am okay with just retrofitting new components into my 1/2-century-old biscuit cooker should one of the oven's now obsolete components fail irreparably. The problem is that I do not what the components now are; I assume a circuit board is probably involved.
One image below shows how my oven converts gas into heat.
Does anyone have a similar image for how the oven in a modern-day Magic Chef works?
Thanks for ANY insight,
Tom
ID:	293284   Click image for larger version
Old 08-26-2017, 04:36 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Actually not much change.
Gas valve, thermocouple, orifice, and burner.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-26-2017, 04:49 PM   #3
Long Island , New York
Ditto to JD.
Tom, what is your rough opening for the oven? Chances are pretty good that a new residential one is available. We love ours, and there is a thread singing the praises of real gas ovens in Airstreams:
http://www.airforums.com/forums/f484...ven-28619.html
Is a modification of your counter possible if only a range/oven is possible?
Cheers,
Peter
Old 08-26-2017, 05:01 PM   #4
TomW's Avatar
1967 26' Overlander
No
Thanks Peter, but I like the cooktop we already have.
Tom
Old 08-26-2017, 05:04 PM   #5
TomW's Avatar
1967 26' Overlander
Cool
Really? I was sure the Safety Folks would have me running 12 VDC into a new product to run a circuit board!
Tom
Old 08-26-2017, 05:15 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Tom
I think the now-ubiquitous circuit boards in fridges and water heaters aren't due to "safety folks" they're due to "lazy folks." While everything is working right, it sure is easier to flip a switch inside rather than crouch down thumbing the striker on an old Dometic or going outside to light the water heater pilot on a windy day. Again.
There are a couple models of fridges and water heaters that are still all-gas without the 12v brain and ignitors.
David
Old 08-26-2017, 05:15 PM   #7
Tom
And the RO for a possible new oven only? Hard to imagine that nothing is available IMO.
Old 08-26-2017, 05:32 PM   #8
TomW's Avatar
1967 26' Overlander
Btw
... We love ours, and there is a thread singing the praises of real gas ovens in Airstreams:
http://www.airforums.com/forums/f484...ven-28619.html...
Peter - take a another look at that thread - I contributed to it early on, and ultimately posted a picture of my oven after cleaning it many years ago.
I E-Z-Offed the oven again today since it seems to be a good thing to do every decade or so...
Tom
Old 08-27-2017, 03:12 PM   #9
1973 31' Sovereign
Middletown , California
In theory you could keep an old RV appliance going forever as long as it's not rusting away. As far as I know parts are still available for ovens but parts for stoves are harder to come by. There are two types of oven controls for the older ones, the one you show has a thermostat that turns on and off a pilot flame which opens and closes the main gas valve to regulate oven temperature. The other type modulates the main burner with the thermostat at the knob. The only difference between RV ovens and household ovens is that the parts are usually smaller or more compact in size but you might be able to adapt generic parts to fit if you really want to save a certain oven. Did you remove the original range and install a stove top in your trailer? I wish I could find one of those old Coleman (I think it was) ranges that were a combination oven and heater!
ijustlee is offline   Reply With Quote
SMEV Italian Ovens/ sinks/ cooktops AeryCorp Commercial Listings 23 10-24-2011 06:18 AM
Eye Level Magic Chef Ovens 71excella500 Stoves, Ovens & Microwaves 0 11-20-2008 12:56 PM
microwave ovens gerry budden Stoves, Ovens & Microwaves 3 10-26-2008 08:19 PM
Speaking of Magic Chef ovens... Chuck Stoves, Ovens & Microwaves 4 06-16-2005 05:16 PM
