Old 05-02-2010, 05:39 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Help find replacement cook top for Magic Chef
I am looking for a replacement cooktop for my 1966 Magic Chef oven, I like the looks of this older unit.
Any Idea's, or any one out there have one or a whole stove they would be willing to part with.
This is rusted enough that it has deep pits in it and where I have been able to polish off the rust it is black. Is there anyway to at least make this look presentable.
Bruce
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 05-02-2010, 06:03 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I don't have anything of that vintage, would it be possible to disassemble it and have the major components powder coated/rechromed? (assuming it still works) Another possibility is to find an apartment unit?
I believe that the standards have changed for RV stoves and the current cooktops don't have the BTU output of the older ones.
Aaron
WBCCI #XXXX AIR #2495
Old 05-02-2010, 06:17 PM   #3
tfbeitz's Avatar
1979 31' Excella 500
1973 25' Tradewind
Cinnaminson , New Jersey
I have used the stainless steel paint after a good wire brushing. not perfect but then not bad for a38 and 36 year old cooktop
Tom Beitz
6760 PA Unit
TAC NJ-5
Riverton, NJ
tfbeitz is offline   Reply With Quote
Old 05-02-2010, 11:06 PM   #4
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
The cooktop and oven work perfectly, I thought about having it chromed but that sound expensive.
tfbeitz: Where did you get your stainless steel paint, do you have any pictures of your work,
Bruce,
Old 05-03-2010, 12:12 AM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
Our '71 Tradewind has similar problems...
How hot do these cooktops get? If someone had one of those infrared temperature sensors gadgets, examining the temp. of the top after boiling water in a large pan would be a good experiment.
There are high temp. powder coat paints available if you want it professionally done.
VHT makes some good high temp. aerosols if you're a DIY sort of person.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-03-2010, 03:28 AM   #6
Lothlorian's Avatar
Loganville , Georgia
Mine looked similar to yours. I took mine and had it powder coated. Car restorers use powder coating for engines. You can get any color you like. I had mine powder coated to look like metal. They put your stove top in a machine that sand blasts every bit of rust off. Then they powder coat. It will look like brand new. Mine still looks like new and we could not be happier. It was not expensive to have done. As a matter of fact I took several pieces of metal in all at once. I had my fart fan screen done also.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-08-2010, 07:52 AM   #7
tbettes's Avatar
1960 26' Overlander
1962 16' Bambi
Smithville , Texas
Good looking used stove and oven from Airstream
Just noticed in Austin Craigslist there is a nice stove pulled and clean from an Airstream. Search Airstream in the For Sale area of Austin TX. Prtice asked was $200.
tbettes is offline   Reply With Quote
Old 06-08-2010, 03:34 PM   #8
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Thanks for the help everyone,
I no long need a stove as I have sold the Globerotter.
Bruce,
Can I paint cook top cover? Anniedog Stoves, Ovens & Microwaves 37 07-27-2010 05:03 AM
1968 Magic Chef Stove Top mharrison@ie Stoves, Ovens & Microwaves 4 04-06-2010 09:34 PM
Magic Chef Stove Top Assembly namm89 Stoves, Ovens & Microwaves 3 10-06-2009 03:16 PM
Cook Top Range Navigator Stoves, Ovens & Microwaves 16 04-22-2004 06:38 AM
