Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 07-08-2007, 10:47 PM   #1
DesertStream's Avatar
Profile:  1966 24' Tradewind
1961 22' Flying Cloud
Montrose , Colorado
Harper-Wyman Oven Thermostat (Magic Chef Range)
Hello All,
After repairing the oven pilot supply line on the Magic Chef range in our 1966 Tradewind the Harper-Wyman thermostat has stopped controlling the oven temperature.
I had found that the 1/8" aluminum supply line for the oven pilot had worn a tiny hole through due to vibration where it passes through the back of the range into the oven compartment. I only discovered this after pulling the range out of the cabinet. The pilot still functioned normally. After replacing the line and reinstalling the range it tested out fine.
At our first use of the oven however we discovered that the thermostat had stopped working. I am assuming that the capillary tube that runs into the oven was somehow damaged as I was installing the new line.
I have been searching for a replacement thermostat with no luck so far. I found a company that will repair ours for $225, but that seems a bit steep.
Any other thoughts?
DesertStream is offline   Reply With Quote
Old 07-09-2007, 03:04 AM   #2
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
If you can, post a picture of the range and the thermostat that would be most helpful. Also what is the model number of your range ? There should be a tag inside the burner area.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Pictures
C Johnson is offline   Reply With Quote
Old 07-09-2007, 08:24 AM   #3
Montrose , Colorado
Here are some photos and the model no.
The Model No. for our Magic Chef range is T720.
ID:	40871   Click image for larger version
Old 07-09-2007, 09:08 AM   #4
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
thermostat
You may see if this will work for your oven, your model is not listed but you may give them a call.
James
http://rvpartsoutlet.com/index.php?cPath=817_46
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 07-09-2007, 01:06 PM   #5
Montrose , Colorado
RV Parts Outlet
Thanks for the lead James, but they said that the thermostat that they offer will not work on our range.
Virgil
Old 07-11-2007, 01:33 AM   #6
volvophile's Avatar
Profile:  colorado springs , Colorado
What is it doing, er- Not doing?
How is it failing?
Is it not turning the burner on when it gets to cold, or is it not turning it off when it gets to hot?
Champagne wishes and Caviar dreams!
Budwieser budget.
volvophile is offline   Reply With Quote
Old 07-12-2007, 10:07 PM   #7
Montrose , Colorado
Symptoms of the Faulty Oven Thermostat
The thermostat does not turn off the gas. It just keeps getting hotter and hotter until you turn off the control.
Virgil
-Virgil and Sheila
It is not down in any map; true places never are. ~Herman Melville
Old 07-17-2007, 05:47 AM   #8
volvophile's Avatar
thats pretty close to the same unit I'm dealing with, Also with a Harper-Wyman, so I'll throw my 2 bits out there.
The pilot assembly has its own capilary tube that opens the main burner valve when its heated by a jet thats turned on by the main thermostat.
So if the pilot assembly is out of alighnment, the cap tube on the pilot assembly could be contacting the flame from the main burner, which would keep the main burner valve open regardless of what the controll is set to.
See my earlier thread with pics of where the pilot is supposed to be.
Budwieser budget.
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 12:34 PM
Magic Chef Oven Thermostat retrocowgirl Stoves, Ovens & Microwaves 1 09-17-2006 11:55 PM
Oven Thermostat PeterH-79MH Stoves, Ovens & Microwaves 33 02-20-2003 10:39 AM
Antenna & Oven Difficulties Tamara General Repair Forum 13 07-30-2002 05:33 PM
No Buns in this Oven NSMITH Stoves, Ovens & Microwaves 2 06-03-2002 08:54 PM
