Old 11-20-2010, 07:59 PM   #29
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
Thanks!!!
I'm hoping it's simple, but it is not obvious to me.
Mike Brumback
WBCCI #1200
Grand Master is offline   Reply With Quote
Old 11-22-2010, 10:49 PM   #30
1963 24' Tradewind
Well, I've discovered that the front end of the valve body (the end nearest the burner knob) unscrews. I haven'tcompletely removed one yet until I understand what is going to pop out. Also, the front panel is not removeable because one of the screws that secures it to the range is under the burner valve manifold pipe. It would be a real pain to remove the manifold.
Does anyone know what the small hole in the collar is for? There is not a pin in the hole. Was it just to insert a small rod to tighten the collar on the valve body?
Mike Brumback
WBCCI #1200
Old 11-25-2010, 10:06 PM   #31
1963 24' Tradewind
I ran across a DIY website that had a remedy for a leaking stove burner valve. Rather than taking the valve apart this service tech recommended using 3 in 1 oil rather than valve salve. In fact, he strongly discouraged disassembling valves.
Here is what he recommended:
1. Use a 3/8" rubber tube and insert it over the orifice nipple shown on the right of the above photo.
2. close the gas line shut off to the stove.
3. put several drops of light weight oil down the rubber tube.
4. While gently pushing and pulling of the burner knob to unseat the valve, blow (with your breath) through the tube to inject the oil into the valve.
5. Making sure no flames are lit, turn on the gas briefly to expel any excess oil from the line.
I had one valve that had a very minor leak detectable with one of those electronic sniffers. After this procedure....... no more leak.
This was sure easier than taking the stove apart to be able to take the valves apart.
I'll keep you posted whether this fix lasts a week, a month, or a year or more. So far, so good.
Mike Brumback
WBCCI #1200
Old 04-07-2011, 12:08 AM   #32
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I tried Grand Masters' remedy on a sticky burner valve that was blowing gas out the front of the stove. After removing the knob I noticed alot of dried crud on the valve stem. I cleaned it off as best I could with the help of a toothpick and I lubricated the stem with 3-1 oil. The knob now pushes in and out freely with no more flame coming through the front panel.
4RXLA is offline   Reply With Quote
Old 05-17-2011, 02:20 PM   #33
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Great tips here, After looking all over Columbus finally found gas valve core grease. Quite pricey but money well spent. As for any other vintage owners this should really be a preventive maintenence routine. My stove valves and shutoffs were in need of some attention.
Thanks Robert
bertro is offline   Reply With Quote
Old 05-18-2011, 07:01 PM   #34
1963 24' Tradewind
The 3-in-1 oil fix for leaky stove burner valves is still leak free. Six months.
Mike Brumback
WBCCI #1200
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
