Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-10-2009, 11:18 PM   #1
Profile:  1976 31' Sovereign
Blairsville , Georgia
Gas smell in oven
The Majic Chef oven in my 76 Soveriegn has a very strong gas smell even with the pilot lit. It's definately coming from the oven, not the top burners or top gas connection. I left the pilot lit for several days and it got unbearable (and scary). But it didn't act funny, blow itself up or anything :-) Anyone got an idea? We plan to move in full time soon and gotta get rid of that smell.
Chip Arnold is offline   Reply With Quote
Old 01-11-2009, 06:30 AM   #2
Dieselgrin's Avatar
Profile:  1973 31' Sovereign
suffolk , Virginia
Start checking all your connections with soapy water. You may be able to rent an LP detector. Hand held ones are not too expensive, but I don't use one often enough to purchase.
Dieselgrin is offline   Reply With Quote
Old 03-21-2009, 06:44 PM   #3
Finally got everything else under control and concentrated on the gas smell. I found that the automatic oven shutoff valve was leaking under the back plate. The o ring seal was mispositioned and it must have been leaking since 1976! In the process I found a handy way to test with soapy water. I filled one of my wifes spray bottles and was able to spray upward from beneath fittings and generally get the solution on stuff that would have been hard to get at otherwise.
Propane smell in oven ! Dan S All Argosy Trailers 12 10-21-2007 12:17 PM
Sewer Gas Smell davespann Waste Systems, Tanks & Totes 15 07-05-2006 10:02 PM
Gas valve malfunctioning in oven Scott_F LP Gas, Piping, Tanks & Regulators 2 06-19-2005 08:27 AM
LP Gas smell when furnace first kicked on Impala SS Guy Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-30-2003 01:08 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
