Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 10-08-2006, 10:18 PM   #1
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
Exact replacement for Suburban NT30MA furnace for 1979 31' Airstream
Does anyone make an exact replacement for the NT30MA furnace of the same dimensions etc, that would allow a drop in replacement?
wacnstac is offline   Reply With Quote
Old 10-09-2006, 08:12 PM   #2
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Hi,
Why don't you call Inland Andy's place? I know he's covered heater interchange before, and they would be the best source of info about this. (I think the SP is the closest match, and, no, it's not a drop-in - if I remember the model number right. Anyway, it gets rid of the pilot.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 10-09-2006, 08:45 PM   #3
Images: 41
Mine doesn't have a pilot.
Old 10-25-2006, 10:39 AM   #4
Profile:
Funace replacement
The Suburban NT30SP is about as close as you will find. It fit my Excella 31 with just a little carpentry and sheet metal work. The wiring is a direct fit, but you have to do a bit of plumbing with the gas connection.
Not a direct fit, bolt-in slam dunk, but not rocket science either. It works wonderfully.
Bill & Jeanne Miller
78 Excella 31 CB
St. Louis
wvmiller is offline   Reply With Quote
Old 10-25-2006, 11:02 AM   #5
Profile:  1976 25' Caravanner
Campton , New Hampshire
I did the same , the only thing different was the gas line moved a bit , pretty simple .
ticki2 is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 07:47 AM
The Perfect AirStream miquael Airstream Motorhome Forums 4 10-02-2002 05:11 AM
Airstream T-Shirts jcanavera Our Community 15 08-15-2002 11:14 PM
My plans for a neet Airstream FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-08-2002 02:30 AM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
