Old 08-02-2008, 10:24 AM   #15
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I'm still trying to picture the altered stove top in my mind. Willyd, since this was originally a 4 burner stove, did the PO leave the stove top intact, removed the 2 front cast iron grates along with the center propane burners and then put in an electric burner plate that matched the width of the two holes in the top?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-02-2008, 10:41 AM   #16
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
When I get back to Florida in a couple of months, I will take more pictures. In any event, I am going to have the electric burners removed and replaced with the originals. Thanks for your comments.
willyd is offline   Reply With Quote
Old 08-02-2008, 10:44 AM   #17
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That is what I would do. Most of our camping is without hook ups and an electric range would not be piratical for us.
Richard
Old 08-02-2008, 10:48 AM   #18
christopher's Avatar
1963 16' Bambi
hyannis , Massachusetts
Speaking of alcohol. What time are you serving drinks??
christopher is offline   Reply With Quote
Old 08-02-2008, 10:49 AM   #19
willyd's Avatar
1993 34' Limited
In response to Craig's comments: It was originally a 4 burner stove. The right two grates and the gas burners were removed and electric burners simply fit into those openings. The range cover fits fine and the only way you can tell is that there is an electrical cord that must be plugged into a recepticle in order to work. The control knobs for electric were also installed in place of the gas knobs. Real interesting setup. I just purchased the Airstream and only know that I would not use the range until the matter is safely resolved. Thanks.
Old 08-02-2008, 10:50 AM   #20
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Smile Scary alcohol
Originally Posted by mustang View Post
Thats a good looking unit you got there. I had to comment on it. I dont know much about the electric issue. I know alcohol is pretty scary.
Just depends on how much you drink.
easyride is offline   Reply With Quote
Potentially dangerous Basecamp leak... and the fix bobfowler Base Camp 7 08-04-2007 08:25 PM
dangerous tongue jack kooblekidz Jacks, Stabilizers, Lifting and Leveling 4 08-15-2005 02:31 PM
Dangerous for Dogs? Edie The Pet Forum 11 05-20-2004 12:28 PM
