Old 10-03-2012, 11:10 AM   #1
Chasmorgan's Avatar
1999 23' Safari
Convection/microwave Heat Question
I recently replaced the stove/oven in my 1999 23ft Safari with a cook top and now would like to buy a Convection Microwave to install in the space formerly occupied by the oven. I've read that a lot of heat is generated by these devices. I feel confident that i have the recommended clearances but i'm concerned about the propane feed line at the back of the compartment. Should I insulate this pipe? If yes how?
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Old 10-04-2012, 06:00 PM   #2
Chasmorgan's Avatar
1999 23' Safari
Just wanted to give this thread another try. Any help is appreciated!
Charlie M
TAC TX-6
Old 10-04-2012, 07:42 PM   #3
nilesrob's Avatar
Marietta , Georgia
Images: 12
We have a convection oven with a propane stove top combination like you describe, but I don't know how the gas line is routed or insulated.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 01-28-2013, 02:30 PM   #4
Loeber's Avatar
Calgary , Alberta
Chasmorgan. Do you have a pic of what you ended up doing? What brand of top did you get? I am dealing with a '79 sov. and would like to get rid of the furnace/stove/oven and go to an electric fireplace / catalytic heater / cooktop / convection microwave set up. The fireplace we are looking at will heat when plugged and a cat. heat for boondocking. An oven seems overkill to us if a convect mircowave will do it. Any help/opinion would be great
Loeber is offline   Reply With Quote
Old 01-30-2013, 11:36 AM   #5
Chasmorgan's Avatar
1999 23' Safari
I purchased a three burner cook top from PPL in Houston. I also purchased the cover. Hope this helps! The stove top is by Wedgewood.
Charlie M
TAC TX-6
Old 01-30-2013, 01:18 PM   #6
Loeber's Avatar
Calgary , Alberta
Thanks Charlie. I am 90% that is the same way we are going to go.
Old 01-31-2013, 12:18 PM   #7
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I ordered my trailer with the convection/microwave combination rather than the oven. (It really is a thermal convection/microwave, but we won't quibble.) You can find a number of comments on this arrangement here on the Forums. Think it's a very personal preference. Some people love the often as you don't need 110V. Others never use their oven. After a year with this setup, I am more than satisfied. It works great in either mode...and does an amazing job with a steak (when I'm not doing it outside on the grill, that is). Also, does a fantastic job with brownies, etc. In terms of heat, I haven't noticed any issue with it.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
