Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 08-13-2007, 07:38 PM   #1
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere , Florida
Circuit Breaker Tripping
We cannot run the 13,500 BTU AC and the Microwave in our 2007 AS at the same time without the 20 amp circuit popping. Doesn't matter if everything else electrical is shut off. Or, if the AC is already up and running. Happened at several campgrounds.
Are others having this same problem.
Tom
henw is online now   Reply With Quote
Old 08-13-2007, 08:09 PM   #2
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
This is normal you have to turn off the AC to use the microwave.
However if your Airstream is set up for 50amp service and you are connected to 50 amp service then you should be able to run them all at the same time.
Garry
Old 08-14-2007, 07:30 AM   #3
Cyclist
henw's Avatar
We're 30 amp.
Thanks...............Tom
Old 08-14-2007, 07:42 AM   #4
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
I've used both the 13,500 BTU AC and the microwave on quite a few occasions without the breaker tripping. I use a good line voltage monitor, and keep a careful eye on the power before I hit the button though.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
a/c tripping breaker? rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 13 08-01-2006 03:59 PM
AC breaker keeps tripping bmimken Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-11-2006 09:57 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 09:45 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 11:21 PM
New circuit breaker strip FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 11:25 PM
