Old 03-29-2010, 12:40 PM   #1
nevada , Nevada
chrome exhaust fan
anyone know where I can find a stove exhaust fan and the nice chrome cover? I'm ditching the ugly overhead exhaust hood and wanting to install the cool looking side wall chrome exhaust fan.
any tips to the location of these is much appreciated, thanks
wolfpack is offline   Reply With Quote
Old 03-29-2010, 01:46 PM   #2
2007 25' Safari FB SE
Eureka Springs , Arkansas
Hi,
I took my Ventline to a sheet metal shop along with templates to change the contour.
They are cutting aluminum pieces that I will pop rivet on the original.
You could also do it in stainless if you wanted a shinier look.
I'm picking it up tomorrow.
triplenet is offline   Reply With Quote
Old 03-29-2010, 02:29 PM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I had the original sidewall mounted exhaust fan chrome plated at a local shop. I'll post a picture when I get home. I don't know where you could score an insidce cover. You'll also need the exterior aluminum cover that when opened, turns on the fan.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-29-2010, 07:40 PM   #4
nevada , Nevada
please post pics
can someone post some detailed pics of the outside flap and a really good close up of the shiny interior fan shroud? sounds like I may have to fabricate one. thanks
Old 03-29-2010, 08:16 PM   #5
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Since its gotten dark, I will take a few detailed pictures of the outside portion tomorrow. Here's the interior cover that I had chromed. Unlike the exhaust fan that was in the hood, this one turns on when you pull on the bead chain. The switch is outside and is activated when the cover is opened.
FF
Old 04-02-2010, 11:58 AM   #6
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Exhaust Fan Shroud Pictures
Sorry for the delay but finally able post some pictures. If you want/need additional shots or an explanation, just let me know.
FF
ID:	99265   Click image for larger version
ID:	99267   Click image for larger version
Old 04-02-2010, 12:06 PM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
The outside cover looks to be about the same as a Hehr vent from the same era. Those are pretty readily available as people change out the Hehr's for Fantastic Fans. The inside part is going to be a bit trickier to come by - but many trailers of the same era used the same vent - so don't limit yourself to finding one form an Airstream. I know I have seen them occasionally on eBay and at the RV junk yard here in town. They might be painted - but that can be stripped if you want...
Shari
Old 04-02-2010, 01:26 PM   #8
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I Googled Sidewall Exhaust Fan and came up with one at VTS (done business with them and can recommend) and another source at mobilehomepartsstore.com (never heard of them, but another source).
Maybe one of these will work for you.
Vaughan
Shower Exhaust Fan Waynon Roof Vents, Skylights & Fans 11 05-28-2017 08:38 AM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Exhaust Fan - which wires go where? kentuvman Roof Vents, Skylights & Fans 8 08-23-2009 06:52 PM
Exhaust fan motor Dr Dan Roof Vents, Skylights & Fans 7 10-08-2008 11:25 AM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
