Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-01-2009, 11:02 PM   #1
Profile:  1961 24' Tradewind
Can this stove be saved?
Here are some pictures of the stove from my '60. It looks bad, the skylight was broken out for 2 years and everything was rained on..
Burners look OK, rust everywhere but its not perforated.
Should I scrap it,sell it, or attempt to repair? I'm gutting the trailer and probably won't restore to original condition.
ID:	73265   Click image for larger version
PetervB is offline   Reply With Quote
Old 01-01-2009, 11:53 PM   #2
Foiled Again's Avatar
Virginia Beach , Virginia
Scrap it
PROPANE appliance.
You'll find a thousand choices between "repair" and "replace" - I simply vote "replace" on anything that can kill you if you don't replace it. Old rusty or corroded metal - add propane, then heat which causes expansion and contraction? It may work short term, but even a pinhole leak can lead to carbon monoxide poisoning or an explosion. You'll spend a lot of time and money rebuilding an old Airstream. Replace the stove, ditto the water heater and probably the furnace too.
An RV Salvage lot or even a local junkyard may have a newer unit that got totalled by a tree falling or a rear end hit - where there was no damage near the stove - you could buy a GOOD second hand stove and cooktop there.
Best wishes on your renovation, Paula
Good luck
Today is a gift. That's why they call it "the present"
Old 01-02-2009, 09:16 AM   #3
Profile:  1972 25' Tradewind
Madison , Wisconsin
Replace it
That repair is probably going to cost more than a new stove. I upgraded much of my trailer rather than restoring it. Even if you are into a restoration a new stove should be kosher.
Smokin Camel is offline   Reply With Quote
Old 01-02-2009, 09:32 AM   #4
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
Go new. I have some burners that are in good shape but are a different style than yours otherwise you could have had them. Good luck.
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 01-02-2009, 02:55 PM   #5
Dieselgrin's Avatar
Profile:  1973 31' Sovereign
suffolk , Virginia
Where do you find a "new" stove top for a 73 Soverign? I thought the same thing about repair/replace. Just need the stove top.
Dieselgrin is offline   Reply With Quote
Old 01-02-2009, 03:03 PM   #6
centennialman's Avatar
Profile:  1966 22' Safari
Centennial , Colorado
I would replace it....the most important concern is safety. Even a rusted through "pin hole" that you can't see could be unsafe.
Steve "Centennial Man"
1966 Airstream Safari - Her name is "Aunt Bee"
centennialman is offline   Reply With Quote
Old 01-02-2009, 04:39 PM   #7
Profile:  , Minnesota
Images: 59
I'm gonna give you a different opinion. I think if the main mainfold (where the valves are) is structurally sound, you shouldn't have a problem.
It looks like the rusted out parts are the tray and crosspieces for the burners. Nothing that can't be repaired with new sheet metal. The bottom of mine was pretty rusty, just lay a new sheet of 24ga steel in the bottom.
Before you do any repair, make sure the oven control works. If it overheats, then you probably need to replace the thermostat, and thats over $100. Then I would think about a new stove. I replaced the thermostat in mine, but I was willing to spend the bucks to keep it original.
Bubble test the range valves.
Old 01-02-2009, 04:39 PM   #8
SMEV Hobs
SMEV Cooktops? Any one tried them?
Read this thread. I may put one of these in my 2006 - when I redo my sink and counter top. They are that cool and I'm considering a 2 burner model to gain some counter space. When I cook BIG, I grill outside. PS: I do have an electric skillet for doing small stuff outside (like bacon which will "linger" in the trailer for a week).
Paula
Old 01-02-2009, 06:51 PM   #9
catson4's Avatar
Profile:  1991 34' Limited
Port Orchard , Washington
Thumbs up I used one GREAT
When we where in New Zealand & Australia in 2006, we leased a "KEA" brand motor home. They both where equipped with the SMEV units like this one.
A cook top and a Grill ( broiler) only. We liked the convenience and the ease of clean up.
I looked at their catalog and this appears to be the current model like we used. Very nice units.
http://www.smev.com/?
Series 402
Hob with crystal lid, grill cabinet feature
If I was to replace my stove, I would be using a SMEV.
Claude
One bazillion fish
1991 34' 60th Aniversary Limited Edition #008
2007 Chevy 2500 HD Duramax/Allison
One big parade float & a 40' Wells Cargo 5th wheel trlr.
"Wake each morning & Smile at the GREAT DAY you about to experience"
www.catson4ponds.com
catson4 is offline   Reply With Quote
Old 01-02-2009, 06:56 PM   #10
catson4's Avatar
PetervB,
I would replace the ol' stove. Looks like a real problem as far as saftey is concerned.
There are a lot of choices but I would opt for the SMEV brand.
Claude
One bazillion fish
Old 01-03-2009, 09:43 AM   #11
....I just wanted to add that I did take my old stove in to a professional appliance place so they could look it over. This was when I first bought my Airstream and I really wanted to restore the original stove.
This particular appliance vendor restores both restaurant and household stoves and they have a classroom where they teach repair folks how to do their job. They really know their stuff.
They, emphatically, said not to give this old stove a chance because of safety......I took their word on it and bought a new one for the Airstream.
I do, however, have a 1952 Vulcan Restaurant range in my kitchen that they restored beautifully.
Old 01-05-2009, 09:27 PM   #12
OK Mark, I bench tested the stove and everything works! bubble tested the valves first, no leaks. then each burner was lit, there's a lack of flame in the center of three of them; probably due to junk in the burner openings. The oven worked perfectly, tested it up to 400deg checking with a oven thermometer. when it reached temperature, the flame reduced in size as expected.
Three questions: is it possible to re-enamel the interior of the oven? What is the recommended paint for the exterior and top tray? and how is the thermal sensor for the oven attached to the upper surface of the oven( mine is hanging loose).
The enamel question will really determine whether its worth a rebuild. I'll probably soak some of the gas containing parts in rust remover and see whats left. that also is a determining factor.
Old 01-05-2009, 09:28 PM   #13
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
State of , Washington
Some of the high temp powder coatings are supposed to do quite well in these applications I've heard. Might be worth a few phone calls.
Scott & Megan
Visit our Blog- http://safari8671.blogspot.com
63 PARTS NEEDED
roof locker tracks (plastic)
square cornered astrodome screen
63 refer, or at least the original door insert
2 12v hehr motors (working) w/ or w/o fan blade
goransons is online now   Reply With Quote
Old 01-05-2009, 09:52 PM   #14
Images: 59
I used POR-20, a high temperature silver paint made by POR-15 company. I has high solids, so it builds fast, and I think it does a good job of filling rust pits. I used it for the tray under the range. The oven interior I left as it was, the procelin coating was in good shape.
The capillary tube is held about 1/4" from the ceiling of the oven, with the end of the tube toward one of the rear corners. I made some standoff clips using a strip of sheetmetal with a hole for the capillary tube, and an offset hole for screwing to the ceiling with a sheetmetal screw. Two clips should do fine.
Stove in my 73 Argosy asilomardad Stoves, Ovens & Microwaves 2 06-02-2007 10:19 AM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 01:22 PM
can this Argosy be saved? zoeb nj All Argosy Trailers 20 11-10-2005 02:11 PM
Stove jeanarlene Stoves, Ovens & Microwaves 25 08-27-2004 09:39 PM
Y'all just saved me a zillion dollars!!! drboyd General Repair Forum 4 06-18-2003 07:34 PM
