Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 03-02-2007, 10:55 AM   #1
hantri's Avatar
Profile:  1973 31' Sovereign
1963 19' Globetrotter
Graham , Texas
Can I Hose the Stove? 63GT
We have taken out the inside. The wood does not look good. Needs new floor, have not seen underneath yet. My questions today:
1) My stove, I want to clean it..can I hose it down or will I ruin something---same for the frig.(NorCold)
2) The water tank in the front--Replace with what?
hantri is offline   Reply With Quote
Old 03-02-2007, 12:50 PM   #2
Tom Nugler's Avatar
Profile:  1972 25' Tradewind
McHenry County , Illinois
Took my stove out a couple of years ago. It was pretty crudded (is that a word?) up inside and out.
Did the inside and burners with oven cleaner. Then finished cleaning the burners and tubes with wire brushes. Disassembled the top panel where the burners and tubes sit and stripped the old paint and rust, then refinished with a high temp engine paint.
As far as the tank goes, some have gone and had new tanks welded up from stainless or aluminum. Do a search, bet you find more than a few ideas.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 03-02-2007, 02:30 PM   #3
Foiled Again's Avatar
Virginia Beach , Virginia
Call your local junkyard!
Unless you're frantically trying to conserve and restore everything to factory spec, you can probably find a newish SOB that's been wrecked with a perfectly good stove. Less work if you can find one that is already pretty clean.... And you'll get a newer stove too.
As for the water tank, I say go plastic. Definitely check the search function. I have seen several threads addressing this very topic.
Happy restoring/renovating.!
Paula Ford
Today is a gift. That's why they call it "the present"
Foiled Again is online now   Reply With Quote
Old 03-02-2007, 02:42 PM   #4
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
With a garden hose?
Originally Posted by hantri
... My stove, I want to clean it..can I hose it down or will I ruin something---same for the frig.(NorCold)
NO on the stove. As far as the oven portion is concerned, the metal interior that you see is insulated with fiberglass insulation. Since the seams are not welded, water will seep in to the fiberglass. While the fiberglass itself will not be hurt, the water it holds will rust the metal it is mounted against. It will also start smelling after a while.
Also, for both the cooktop & oven, any water that gets into the pilot or burner assemblies will end up rusting something & eventually produce rust flakes which could clog the system and result in non-operation.
Tom
Old 03-02-2007, 03:04 PM   #5
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Ditto on "NO". We did take ours apart, clean and sand & repaint the body of it. The outside (exposed) appliance paint was good...but the "under burner" area had some neglected overspills which had started to corrode the paint there. Much better now and easy to clean-up any new spills that occur.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 03-02-2007, 07:41 PM   #6
hantri's Avatar
Graham , Texas
Thanks for the replies... Our stove has been painted by a PO---DH wants to do without stove--I just love the look of the old. Not experienced enough to know what we want. Do not even know yet if it works.
Paula----I agree definitely plastic for the tank!!
Old 03-02-2007, 08:27 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 87
Here's a plan:
1) figure out if it works
2) if so, can the paint by PO be removed...try something gentle to strip or just repaint a new color
3) if not, decide if you really want a stove (I hope you mean oven) we love ours! nothing like warm pastrys on a chilly morning
4) don't throw anything away until you are sure...and then offer it to another forum member. "One Airstreamers trash is another's treasure"
Shari
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
Fred vs. Hose Reel 1985air345 Airstream Motorhome Forums 10 09-01-2007 08:34 PM
Stove jeanarlene Stoves, Ovens & Microwaves 25 08-27-2004 09:39 PM
GrandMa's Stove 77caravaner Stoves, Ovens & Microwaves 0 10-08-2002 06:05 PM
LP Hose from Reg. to Trailer niftypkg LP Gas, Piping, Tanks & Regulators 2 06-20-2002 10:09 PM
