Originally Posted by hantri
... My stove, I want to clean it..can I hose it down or will I ruin something---same for the frig.(NorCold)
NO on the stove. As far as the oven portion is concerned, the metal interior that you see is insulated with fiberglass insulation. Since the seams are not welded, water will seep in to the fiberglass. While the fiberglass itself will not be hurt, the water it holds will rust the metal it is mounted against. It will also start smelling after a while.
Also, for both the cooktop & oven, any water that gets into the pilot or burner assemblies will end up rusting something & eventually produce rust flakes which could clog the system and result in non-operation.
Tom
