Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 04-07-2009, 05:28 PM   #1
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
Broken Tubing In Oven
When we bought our '01 25' Airstream, the small 3/16" aluminum tubing that goes to the pilot light was broken where it enters the pilot light assembly. I repaired it by splicing the tubing to get some extra length to replace the part that was broken off. It was broken right at the compression ferrel. The alternative was to remove the oven to replace the tubing as it enters the oven from the rear.
On our trip last weekend, I found the tubing broken again at the same spot. It must be moving during transit and hardening at that spot, causing the break.
Just wondering if anyone else has had this problem, and if so, what was your solution?
Old 04-07-2009, 06:47 PM   #2
VIKING's Avatar
Profile:  1964 22' Safari
Boulder Creek , California
I saw a thread about this same problem a few weeks ago but I can't find it now. I remember that Silvertwinkie was one of the posters though. You might check his previous posts and find it there. I remember one solution was to replace the whole tube with copper which requires removing the oven. It sounded pretty easy to do.
I wouldn't be surprised if there is a recall on those ovens, as this is a serious defect. more than one of the posters had the full fireball-in-the-trailer thing happen.
Be careful, Rich
See my blog: http://1964airstreamsafari.blogspot.com/
VIKING is offline   Reply With Quote
Old 04-07-2009, 07:58 PM   #3
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
Here's that thread:
2004 Amana oven problem
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 04-07-2009, 08:25 PM   #4
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Yea, Crazylev is right. I just re-installed it this past Sunday. I plan on updating with some photos later. I would not re-use that POS alum line. I spent maybe $15 on my fix which thanks to the posters of the linked thread got me to where I am now, a fix that will not break, is not over torqued or stressed which caused it in the first place.
There really should be a reacall on this oven. This is a potential issue of some significance. Three things you don't mess with, things that burn LP, your running gear or your hitch.
Old 04-07-2009, 08:59 PM   #5
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Looking at the first picture in post 33 of
I would say the problem is a result of overtightening the nut on the pearl. When a brass pearl is used on aluminum tubing the aluminum is much softer than the brass and the edges of the pearl cut into the aluminum. If overtightened the aluminum tubing is cut almost like a beer can top. Any additional vibration after that will brake the tubing.
If it were mu stove I would replace the tubing with copper tubing and consider a service loop in the tubing just before the connection and support the end of the loop farthest from the pilot.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
fixed broken oven handle Isadora Stoves, Ovens & Microwaves 10 04-13-2008 08:28 PM
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 0 09-28-2007 08:45 PM
Oven Pilot Problem - Broken Line gadgetat LP Gas, Piping, Tanks & Regulators 6 02-10-2007 07:36 PM
E-PEX tubing Pahaska Fresh Water Systems 3 03-03-2003 01:03 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
