Old 12-27-2015, 09:16 AM   #1
1972 23' Safari
Norwalk , Connecticut
Baraldi Hood vent position compatibility
Can anyone advise if the Baraldi hood is compatible with the existing vent position on a '72 safari? It looks like I t vents out the back, where our original vent goes up into the cabinet.
Widget is offline   Reply With Quote
Old 12-27-2015, 10:02 AM   #2
1974 Argosy 20
Kooskia , Idaho
I don't believe so. The original range vent on your era Airstreams was an Airstream designed system, filter, fan, ductwork and outside cable operated opening. The current range hood is an all in one unit, sourced by Airstream, but not built by them. The openings are not the same, or in the same place.
Baraldi Vent Hood power switch ghaynes755 General Repair Forum 12 10-16-2017 10:53 PM
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 02:41 PM
Buttons on Baraldi range hood loberg General Repair Forum 5 09-10-2015 12:34 PM
Slightly used Baraldi Range Hood Snaken49 Airstream Classifieds 0 01-26-2015 03:37 PM
LED Conversion: Baraldi Range Hood Lights TinTin Lights - Interior & Exterior 5 07-13-2014 03:38 PM
