Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 06-30-2009, 06:01 AM   #1
redhawkerII's Avatar
Profile:  1970 27' Overlander
no cities , Traveling
Images: 14
Send a message via Yahoo to redhawkerII Send a message via Skype™ to redhawkerII
'Airstream custom pilot light'
We usually store certain canned food in our oven as a space saver...but last night I needed to run up some sort of special bread...so the pilot light is always lit, thats one way we can see our propane is o.k. at a glance. Anyway when I went to turn it on and it came on the flame from the pilot got bigger and was burning yellow. now when the oven is not being used, the pilot flame is blue without any yellow at all. The name on the front of the oven is called ;airstream custom'...any tips?
...Lots of people want to ride with you in the Limo, But what you want is someone who will take the bus with you when the Limo breaks down....http://smileys.smileycentral.com/cat/23/23_30_126.gif
redhawkerII is offline   Reply With Quote
Old 06-30-2009, 06:09 AM   #2
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 99
Airstream Registry
redhawkerII,
The pilot flame will get larger and yellow when you turn the oven on. When you turn the oven on the pilot light gets larger to heat the thermocouple which opens the valve to allow the oven burner to ignite. Once the thermostat is satisfied the burner will shut off, but the pilot will remain large and yellow to keep the thermocouple heated for future heating cycles to keep the oven up to temperature. When you turn the oven off the pilot light should go back to its standby state which is smallish and blue.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package Katarina
1987 34' Excella 1000 Double Door Savannah
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
AIR #14487
WBCCI #7429
DEITZ645 is online now   Reply With Quote
Old 06-30-2009, 06:13 AM   #3
Profile:  2008 16' Safari
Destrehan , Louisiana
It should be a blue flame. The yellow means that the fuel/air mix was wrong. This is usually a gas pressure problem. Check your gas regulator. It can also be caused by a little air in the gas system. Did you change gas bottles recently?
dlb435 is offline   Reply With Quote
Old 06-30-2009, 07:25 AM   #4
grtwhthuntr's Avatar
Profile:  1972 31' Excella 500
Lagrange , Kentucky
The pilot orfice is probably dirty. A brass wire brush usually cleans them up well after disassembly. DO NOT force an item into the orfice to clean. This will enlarge the hole forever changing the gas/air ratio. Cleaning the white ash off of the thermocouple is important also.
Another note...if the pilot has been dirty for a while, once you clean it, the flame pattern may change disrupting the thermocouple properties causing it to fail. Thermocouples are cheap, if it old or has been dirty for over 6 months go ahead and change it while you are in there.
good luck
grtwhthuntr is offline   Reply With Quote
Old 06-30-2009, 07:35 AM   #5
Images: 14
Yes we just switched tanks not too long ago, and like I mentioned, we have not used it for about six months and were storing certain safe canned stuff in there...so when we lit the oven itself I was just hesitant about seeing the larger yellow flame. Thanks for your help in this matter.
Old 06-30-2009, 08:14 AM   #6
Profile:  1995 28' Excella
Helotes , Texas
Smile
We just experienced the same problem, our Airstream friend knew the problem and fixed it for a cost of lessthen $5.00. The aluminum tube that feeds the pilot ligt was broken from the constant vibration I assume) a small length of 5/16 th tubing, a compression union and a compression derrel and fixed. He also made it longer and put a 360 degree in the tubing to absorb some of the vibration much the same as on the autos
lsmith is offline   Reply With Quote
Pilot light goes out on furnance tinlizzie2 Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-06-2009 12:09 PM
Pilot light works, but heater does not seem to light FLYNCLD Water Heaters, Filters & Pumps 6 06-13-2009 08:57 AM
Furnace Pilot Won't Light pinktrailer Furnaces, Heaters, Fireplaces & Air Conditioning 12 04-15-2009 07:17 AM
Pilot Light Silver Threads LP Gas, Piping, Tanks & Regulators 19 02-24-2007 09:08 AM
Can't light furnace pilot light? (again?) PodPeople Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-05-2005 11:52 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
