Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-03-2009, 08:27 PM   #1
Dieselgrin's Avatar
Profile:  1973 31' Sovereign
suffolk , Virginia
73 Magic Chef oven is ALIVE!
Well, after messing with the MC on and off for a month of so I finally found out the problem.
The oven pilot wouldn't light and I tried everything. All the turn the dial to this; turn the stove on; etc. no joy. Found the cut of valve behind the face plate, it was on. So I took a torch cleaner and cleaned the pilot hole. Nothing. Finally I just started taking things apart. The cut off valve to the carburetor, no gas. Connection under the sink, no gas. The cupeling at the tee under the trailer, GAS. I ran weedeater string in each run and found a clog in the line 3' from the tee under the trailer.
I connected everything, checked for leaks with soapy water, and lit the pilot. Then I turned up the oven..... we have FIRE! I'm going to check the temp tomorrow.
Dieselgrin is offline   Reply With Quote
Old 01-03-2009, 08:34 PM   #2
cameront120's Avatar
Profile:  1972 25' Tradewind
Congrats! You can pick up an oven thermometer from any cooking shop. I did this and was surprised to find my oven quite close to the dial settings.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 01-04-2009, 08:06 PM   #3
Dieselgrin's Avatar
suffolk , Virginia
Well, tonight I baked a pizza for my bride in our "new" Magic Chef oven. It was perfect! Wish all the projects would turn out so favorable.
Magic Chef Oven danesh Stoves, Ovens & Microwaves 34 03-31-2009 03:21 PM
Magic Chef Oven For Sale later Stoves, Ovens & Microwaves 9 10-30-2008 09:30 AM
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 12:34 PM
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 0 09-28-2007 08:45 PM
Oven problem on Magic Chef tincanalley Stoves, Ovens & Microwaves 2 07-18-2006 09:33 AM
