Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Prev Previous Post   Next Post Next
Old 03-20-2009, 02:18 PM   #1
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
'72 cooktop w/ yellow flames! Help!
Hi- my original '72 4-burner cooktop works well on 3 of the burners, but the 4th spews yellow flames. Up near the front of the unit, by the on/off valves, are baffles that can be adjusted, for air inflow, I guess. All 4 are adjusted about the same (1/2 open), and monkeying with it did not get rid of the yellow flame. Just in front of these baffles is a threaded, brass fitting, inside of which is a needle valve, of sorts. What function does this fitting serve, and what effect does either tightening or loosening this fitting have? Does it have anything to do with gas output/ mixture etc,? This faulty burner also does not readily light from the pilot, so something is amiss here. Could the fault lie in the burner itself, a disintegrated gasket maybe, or some other air leak causing the yellow flame? Thanks for any info!
tphan is offline   Reply With Quote
Magic Chef Oven Pilot flames/blows out HansenClan LP Gas, Piping, Tanks & Regulators 3 09-22-2008 11:28 PM
Cooktop help! paulb Stoves, Ovens & Microwaves 1 11-20-2006 04:40 AM
Best Cooktop? KHarris Stoves, Ovens & Microwaves 2 09-24-2006 04:22 PM
Up in flames fuzzywickle Our Community 7 09-23-2005 11:24 AM
got flames? john hd Airstream Motorhome Forums 3 02-09-2003 08:54 PM
