Old 04-19-2011, 10:34 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
'65 Magic Chef Oven Thermostat
We are trying to finish a few last projects and the oven is one of them. We finally got the oven to work and tried using it. The outcome was charred brownies and smoke. We think the thermostat is bad. Does anyone know if this is a part that is still available? Or any ideas on where to find said part?
Thanks.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 04-19-2011, 11:29 PM   #2
walter1's Avatar
1964 22' Safari
Foresthill , California
Not yet, I've been looking for 5 years...not giving up yet...I want brownies!
Antiquegasstoves tested mine...bad. They can rebuild, almost $200.
I'm collecting old ones to reverse engineer a fix. I need a few more. If you do find a source for spares please let us know.
walter1 is offline   Reply With Quote
Old 04-19-2011, 11:50 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Thanks.
I had the exact problem with brownies a number of years ago in our 65 Caravel. After much looking, I found a place that would sell me a rebuilt thermostat with no guarantee for, as I recall, about $100.
I opted for a new Magic Chef range with oven. It fit the hole, and gas hooked up with no problem. Changing it out was a ten minute job. The top of the new range is much easier to clean and it has worked perfectly.
If you want to use the oven, get a new range. Don't mess with the old one.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-20-2011, 05:05 AM   #4
Images: 59
I got a new Robertshaw thermostat from Stoveparts.net for $125.
Great brownies.
Old 04-26-2011, 11:38 PM   #5
walter1's Avatar
1964 22' Safari
which part#
WHOA!! Score!
Do you recall which specific Robert Shaw thermostat part number you purchased from the stoveparts.net page?
Did you have any issues installing, hooking it up?
I've spent way more than $125 in time and overpaying my staff engineers (kids) to reverse engineer fix for the old ones. Really, I'll buy two tomorrow.
Thanks a lot for sharing parts source.
I smell brownies at last !
Old 04-27-2011, 12:21 AM   #6
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
you can calibrate them too, by taking off the knob and using a thermometer in the oven... there is a screw you turn to raise or lower the temp vs the setting
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-27-2011, 05:22 AM   #7
Images: 59
I got the TRM-01001. It's a Robertshaw BJ type with a 250 to 550 degree operating range.
The only issues I ran into during the install was finding the correct orientation and some trimming for access to one of the adjusting screws. As I recall, you can rotate the thermostat rear cover 90 degrees to accomodate different mounting arrangements. Straightforward and covered in the instruction sheet. You can download the instruction sheet at the stoveparts website.
The other issue was access to the pilot adjusting screw, which was blocked by the front frame of the stovetop. It was easy to snip out part of the frame. I used a strip of steel to bridge the gap but that isn't really necessary. The modification isn't visible after you reinstall the front trim panel. Here's a picture.
Old 08-16-2011, 11:44 AM   #8
1972 27' Overlander
Saline , Michigan
I have a 1972 27' International with the Magic Chef Wall oven, thermostat does not work. Here is my model info:
Magic Chef Oven L T932-2SV-B2 12V DC
Will the TRM-01001. Robertshaw BJ thermostat work in my wall oven? anyone replace thermostat in this magic chef wall oven? Really want to get the oven going again.
loechli is offline   Reply With Quote
Vintage Magic Chef Oven Operation Primer TouringDan Stoves, Ovens & Microwaves 28 11-03-2016 07:15 AM
Magic chef oven cathy72417 Stoves, Ovens & Microwaves 0 08-05-2011 07:56 AM
looking for help with Magic chef oven pilot light jayg Stoves, Ovens & Microwaves 2 06-01-2011 04:18 PM
Calibrating late 70's Magic Chef oven blickcd Stoves, Ovens & Microwaves 2 04-02-2011 11:23 AM
Magic chef oven Autumn Stoves, Ovens & Microwaves 15 01-25-2011 11:38 PM
