Old 07-11-2010, 11:07 AM   #1
1960 24' Tradewind
Janesville , Iowa
60's apartment size Magic Chef in Airstream?
I just found this mint apt. stove/oven in a junk shop and thought "why not in the airstream". Does anyone know if the pressure from the 30lb. tank will work with residential stuff??
badger is offline   Reply With Quote
Old 07-11-2010, 11:13 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I believe that you have to change a valve or orifice anytime you change from natural gas to propane. A stove restoration shop should know what to do or a propane distributor.
Airstreams in the 1950's used apartment size 20" wide stoves as there were no RV appliances then.
Bill
Just my personal opinion
Old 07-11-2010, 12:21 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Shoot, mine is a 68 and it's twice the size of the new ones i can fit a turkey in it 15 lb
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Magic Chef needs magic fix Sheridan Stoves, Ovens & Microwaves 8 11-21-2009 03:44 PM
Need help with an old Magic Chef oven bigjohn Stoves, Ovens & Microwaves 1 03-22-2009 08:07 PM
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 11:34 AM
Looking for pictures of early 60's Magic Chef oven Pilot assembly volvophile Stoves, Ovens & Microwaves 9 07-04-2007 05:33 PM
Magic Chef Stove Tin Lizzy Stoves, Ovens & Microwaves 2 06-20-2006 02:20 PM
