Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 10-14-2003, 12:04 AM   #1
Jim Tyrney's Avatar
Profile:
Question 1986 AS 345 MH Magic Chef Shut off Valve?
Me again!!! Does anyone know if there is a cut-off vavle for the range top inside the 345? I have looked and see the gas line going into the wall but not sure where it goes from there. I would like to cut off the supply to do some maintenance plus shut off the pilot light. Hopefully it is not just the main valve at the tank!! Thanks for any response/help.
"Property doesn't have rights, people have rights to property"
Jim Tyrney is offline   Reply With Quote
Old 10-14-2003, 06:52 AM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
Cutoff Valve
There is no cutoff valve on my '87 345 except for the main valve at the tank, and the valves internal to the range.
If you need the range top to be down for maintenance, it would be very easy to cut and flare the copper gas line behind the cabinets, and install a shut valve.
As an alternative, the line to the range is exposed and accessible on the bottom (roadside) of the coach, just behind the step assembly. A cutoff valve could easily be installed there also.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 10-14-2003, 02:48 PM   #3
Jim Tyrney's Avatar
Profile:
1986 345 MH Magic Chef Cutoff Valve
Dennis,
Thanks for the reply and I guess I can stop looking for a valve. I will probably install one externally, that way it will isolate LP to outside. Thanks
1986 AS MH 345 Air Suspension Jim Tyrney Airstream Motorhome Forums 2 01-05-2004 03:42 PM
86 345 MH Grey Water Valve Extension Jim Tyrney General Motorhome Topics 1 11-17-2003 09:50 PM
1986 AS 345 MH H2O Check Valve Location Jim Tyrney Airstream Motorhome Forums 10 10-21-2003 08:47 PM
1986 As 345 Mh Jim Tyrney General Motorhome Topics 4 10-16-2003 12:15 PM
1986 As 345 Mh Jim Tyrney General Motorhome Topics 3 10-10-2003 07:15 PM
