Old 09-25-2015, 05:11 PM   #1
2000 28' Excella
Mount Juliet , Tennessee
Works Great On Electric But Not Gas
We have a 28' 2000 Excella trailer. Our refrigerator was running fine but on our way to New Mexico in June it stopped cooling on gas. The panel on the refrigerator indicates that we are running on gas it isn't cooling. The "Check" light isn't coming on so the refrigerator thinks it's doing the job. It works fine when we are plugged in to 20 or 30 amp service so I don't believe that it's a coolant issue.
It was hovering around a 100 most of the trip so I thought the heat might have been the problem. In our travels this fall temperatures were in the 60's and 70's when we were on the road and we still had the problem.
Has anyone run into this problem? Is the only solution moving perishables to an ice chest when traveling? That was our solution after loosing a lot of food.
raynickel is offline   Reply With Quote
Old 09-25-2015, 05:46 PM   #2
Make sure your LPG pressure is between 11 and 13 inches of water column pressure.
Clean the burner orifice.
Then make sure the air adjustment is correct.
That should do it, since that's all that can be done, assuming the thermostat is ok.
Fridge not working with Gas, still works w/electric Tim_S Refrigerators 3 09-02-2011 05:06 AM
Air conditioner works, but not cool starflyte1 Furnaces, Heaters, Fireplaces & Air Conditioning 50 09-25-2010 12:20 AM
Dometic Fridge works on AC but not gas tubbinator Refrigerators 5 09-12-2006 06:02 PM
Freezer works on propane - but not fridge adamstarr Refrigerators 2 08-14-2006 12:53 AM
New Radio/CD works on 12V but not 110 Austin Runner Electrical - Systems, Generators, Batteries & Solar 3 04-25-2004 07:20 PM
