Old 05-15-2016, 10:49 PM   #15
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Originally Posted by Earthcreeper View Post
Is propane an option??
Absolutely. The assumption is that the fridge will be cooled via propane while the fridge's controls (thermostat, etc.) will consume some energy from the battery.
The general consensus from those who have done it for 3 days and more seems to be, "Yes, and maybe even longer."
I was being more cautious because (1) I've not tried it for more than a couple of days and (2) the capacity of our stock batteries is a frequent concern whenever we boondock.
Rocinante is our 2014 International Signature 27FB
Old 05-16-2016, 03:05 AM   #16
Long Island , New York
The original post below says, in pertinent part, that the fridge would be running on propane.
Originally Posted by Llando88 View Post
Will my battery last long enough for the whole three days to supply 12V while it runs on LP?
Old 05-16-2016, 02:53 PM   #17
Dallas Center , Iowa
No title
OTRA15. Cute use of the imoticons. Thanks for pointing out the obvious. As you are, I too was interjecting a little fun. Sorry about the dry humor. I got it from my dad. Happy trails! 😉 😂
Earthcreeper is offline   Reply With Quote
Old 05-16-2016, 11:27 PM   #18
Llando88's Avatar
2016 30' Flying Cloud
So, just an update: yesterday I saw 12.4V on the meter, I'm guessing they weren't as fully charged as I thought.
Anyway, this morning I had 12.0V. So I'm not sure I'll get to Wednesday morning. I'm going for a long drive tomorrow to give it a boost so hopefully I'll be ok.
Thanks again; I'm continually impressed how helpful this forum is.
Rich
PS for those wondering, we had a chance to spend three days in Vegas at short notice, but I had to put the RV out in the Nevada sun.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 05-16-2016, 11:32 PM   #19
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We put a switch in the power wire to the sub woofer power since it was on all the time as a parasite power hog.
Old 05-17-2016, 02:27 AM   #20
Not sure what loads you have had on your batteries but they seem to be dropping pretty fast to these eyes. Are you sure no other 12v items are on, like the lights in the storage compartments? You might want to check the battery water level in each cell, and test each with a hydrometer. Your new AS may have not been stored correctly by the dealer before purchase, and it is possible the batteries were compromised IMO. The fridge control panel does not draw much voltage, as I understand it anyway.
The earlier suggestions of a good cooler with lots of ice (or dry ice?) may be worth the investment. We keep a couple of coolers in the tow vehicle (van with lots of room), and often put the fridge items in the coolers, when needed for situations like this. Ice in bags is available almost everywhere, albeit at a cost.
Good luck!
Peter
PS -- Does switz's comment about the sub-woofer apply to your unit? Also, per an earlier comment, are any hidden AV radio etc. units in Stand By mode and drawing power unbeknownst to you?
PS2 -- May be time to consider a small generator converted to run on propane? We ordered the Yamaha 1000 which is on back order, but you may need the 2000? Those units by US Carburation apparently include the Yamaha OEM warranty.
Old 05-17-2016, 01:09 PM   #21
Llando88's Avatar
Will my Fridge last three days on Battery?
Not sure either. ^^^
We're getting out of Vegas tomorrow, so next chance I get, I'll nose around for parasitic drains.
That subwoofer comment sounds interesting. Pretty sure the Clarion boat stereo is off, but I didn't recall we had a subwoofer until now.
Rich
Edit to add: I did find a fused power wire running to the subwoofer today, so I've disconnected that. Hope is if it was drawing power, it will be eliminated as a load.
I've checked everything else on the suggestions above, all are off, save that LP detector.
Actually thinking about it, I've been leaving the store/use switch in the store position lately. It's possible I didn't arrive at the hotel parking lot at 100%. But yeah long term plan is probably a Honda 2kw gennie in the back of the truck, as soon as finances allow.
Old 05-17-2016, 01:43 PM   #22
Rivet Slave
Rocinante's Avatar
Woof!
Had no idea the sub woofer was "always on." That would be a totally lame parasitic draw. Thanks for noting it.
Old 05-17-2016, 02:21 PM   #23
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hope you made out OK with your reefer. We left ours stored and after 4 days the batteries were low enough to cut the reefer off. We hooked up and drove off. I monitored the refrig a few times along the way and it took 4 hrs. of driving for the batteries to get enough ooomph in them to start the refrig. The point here is that expecting batteries to charge while under way is a Slooooooow process.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-18-2016, 05:24 PM   #24
Llando88's Avatar
^^^ Copy that.
Voltage was 11.8 this morning on departure from the hotel. Fridge was fine.
Old 05-18-2016, 05:32 PM   #25
^^^ Copy that.
It is my understanding that a voltage of 11.8 damages your batteries. Have you checked the water levels and specific gravity with a hydrometer? Per earlier comments your batteries may have been damaged at the dealer before purchase. Sorry to be repeat this one more time -- over and out on this issue.
Good luck!
Peter
Old 05-18-2016, 05:57 PM   #26
lewster's Avatar
Naples, FL , Hood River, OR
Good luck!
Peter
An occasional deep draw to 11.8 VDC will not necessarily damage your batteries, especially if they are fully recharged to 100% in short order.
It might effect their longevity however and the number of charge cycles they will deliver.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Last day of camping before winter storage....sad days indeed:( Gilmurr Airstream Lifestyle 1 10-28-2013 08:33 AM
Off topic forum, last two or three seconds are phenomenal. toastie Off Topic Forum 2 12-03-2011 07:35 PM
Went airstreaming in Southern Illinois for three days Lothlorian On The Road... 2 10-12-2009 10:49 PM
There have been no posts in the last 365 days in this forum. trucker101 1970 - 1973 Sovereign 2 08-29-2008 11:05 PM
