Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 10-24-2011, 11:23 AM   #1
2008 19' International CCD
Hidalgo , Texas
Why does my fridge freeze my food?
My fridge on my 08 international 19' freezes my food. Is there a way to change or adjust the temp?
Armando is offline   Reply With Quote
Old 10-24-2011, 12:29 PM   #2
SteveH's Avatar
Common Sense , Texas
Ours will also if we turn it down to the coldest setting, and it's not too hot outside. Don't know about the specific frig you have, but ours has a temp setting on the front, top, above the door.
I've never seen one that didn't have a temp setting.
Regards,
Steve
Old 10-24-2011, 01:24 PM   #3
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Look inside the refrigrator.
On the back wall in the refrigerator, you will find an aluminum heat exchanger with five or six fins.
On one of the fins you will see a plastic clamp with a wire running from it.
Sliding this clamp up and down regulates the shared cold between freezer and refer.
It is sometimes called a thermistor, but I'm not sure that is technically correct.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-24-2011, 02:16 PM   #4
The thermocouple is bad.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-24-2011, 03:36 PM   #5
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
My fridge was also freezing food and not staying lit during high winds on my last outing. Possible bad thermocoupler for my refrigerator as well?
It would stay lit during calm conditions but it would get blown out easily by wind.
star kitty is offline   Reply With Quote
Old 10-24-2011, 03:41 PM   #6
Check the LPG pressure.
It should be between 11 and 13 inches of water column pressure. Best to be at 12 or 13.
Next, clean the burner, the orifice and the reefer flue.
Lastly, the above will keep the burner going, but the freezing usually means the thermocouple has braoken and then can't tell the burner to back off.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-24-2011, 05:26 PM   #7
aftermath's Avatar
Spokane , Washington
What Alumaholic said. If it is too cold, move it down. If it is too warm, move it up. I had a friend that had packed his fridge a little too full and in doing so, moved this little device down too far. Something must have banged up against it. Things got warm and when he looked at the plastic thing he noticed that it looked different.
I would try this first. Then you can get into those other "parts."
Good luck.
aftermath is offline   Reply With Quote
Old 10-24-2011, 07:02 PM   #8
65CV's Avatar
Western , Massachusetts
Followup question
Hopefully Armando won't mind another question on his thread -- I think it's relevant.
How much variability should we expect with outdoor temperature when running propane? We seem to see variations that cause freezing at times when the outdoor temperature drops.
John
65CV is offline   Reply With Quote
Old 10-24-2011, 07:51 PM   #9
Hidalgo , Texas
I was wondering what that plastic was, thanks I just slid it down and I'll wait and see, I'll let you guys know what happens, thanks!
Old 12-10-2013, 01:16 PM   #10
tarh2o's Avatar
1975 25' Tradewind
Boerne , Texas
Different Configuration of Thermistor
All,
I too am having this same issue where my fridge is on its lowest setting before being off and its still freezing my food. I've noticed the wire coming from the back of the fridge and going up to the aluminum fins. It is held in place with a metal "W" channel and screws and is not directly attached to the metal channel.
So how exactly would I "slide" the probe up or down? Should I just loosen the retaining channel and pull the wire down?
Any help would be appreciated.
TARH2O
1975 25' Airstream TradeWind International - Under Renovation
2012 MB ML350 BlueTec
tarh2o is offline   Reply With Quote
Old 12-10-2013, 01:23 PM   #11
Originally Posted by tarh2o View Post
All,
When the reefer thermostat no longer controls the temperature, it tells you that it's shot.
Typically, the thermocouple breaks because of vibration, making it useless.
What causes it to break in time ??
Improper running gear balance, bad rubber rods in the axles, and sometimes extra heavy duty tow vehicles and/or hitch ratings.
But, the fix is to replace whichever thermostat is bad, and then correct the cause of the problem.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-10-2013, 05:45 PM   #12
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
The "W" channel holding the probe can be slide up or down on the fin (mine is plastic, not metal). I believe sliding it down on the fin causes the temp to be warmer. Try that.
Usually people have the opposite problem of the fridge becoming too warm because the thermistor (probe) has gone bad.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 03-12-2014, 09:29 AM   #13
Jim & Mitzi's Avatar
1987 32' Excella
1990 29' Land Yacht
Americus , Alsrural Bristol Tn.
1997 safari dometic 2862>? 2 door appears likel new. worked fine for months now freezes in fridge section also. New adjustable thermister...no change. Next thing to change would be ????? Been turning on and off to try and keep fridge from freezing.
Jim & Mitzi is offline   Reply With Quote
Old 03-12-2014, 10:34 AM   #14
The fridge is freezing because the thermostat probe tubing is broken.
Therefore there is zero feedback from the reefer to the thermostat.
Accordingly, the thermostat tells the reefer to "cool" since it has no info to work with.
What causes that tubing to break???
Lack of proper running gear balance (vibration).
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-12-2014, 11:56 AM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Sometimes over rough roads that probe just simply falls off- or the metal part that slides up and down has just fallen off and is lying on the shelf-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-12-2014, 04:10 PM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Is improperly balanced running gear the only cause for anything to break?
Old 03-12-2014, 05:03 PM   #17
m.hony's Avatar
2013 30' Classic
I think bad roads around here would beat it to death even with Centramatics...
My Velcroed curtains in my other trailer used to fall off the windows.
I come in the trailer and I be like, "Hey! Where's my curtains?"
Curtains be behind the couch.
I have found the metal part you slide up and down to control temperature just lying on the shelf. I assumed it vibrated off over time traveling bad roads.
All roads are getting worse. Ain't nobody got no money to fix no toads...
TAC #MS-10
Airforums #70955
Old 03-12-2014, 06:50 PM   #18
r carl's Avatar
Lin , Ne
If the aluminum tube is vibrating, it will fatigue and break.
Old 03-14-2014, 11:19 AM   #19
1987 32' Excella
1990 29' Land Yacht
1997 safari Dometic RM 2652
Correcting prev input. RM 2652 is correct model. Replaced OE thermister with a Articca adjustable thermister. NO change. Fridge still too cold. AC power only so far. Have NOT run on propane yet.After changing the thermister, what part would be next to look at ? Have been turning fridge on and off to keep temp somewhat under control. Something needs to be telling the AC heater to stay on vs: cycling on and off to maintain proper temp. All input is appreciated.
Old 03-14-2014, 11:52 AM   #20
The electric thermostat is shot.
Andy Rogozinski
Inland RV Center
Corona, CA
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
Food Trailer Custom Built Airstream (Food Truck) eBay Watch Airstreams on eBay 0 05-06-2011 08:00 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
Why does front A/C have drain hose but back A/C does not? AccessMaster Airstream Motorhome Forums 9 06-22-2003 07:15 PM
