Old 03-12-2014, 11:56 AM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Sometimes over rough roads that probe just simply falls off- or the metal part that slides up and down has just fallen off and is lying on the shelf-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-12-2014, 04:10 PM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Is improperly balanced running gear the only cause for anything to break?
Old 03-12-2014, 05:03 PM   #17
m.hony's Avatar
2013 30' Classic
I think bad roads around here would beat it to death even with Centramatics...
My Velcroed curtains in my other trailer used to fall off the windows.
I come in the trailer and I be like, "Hey! Where's my curtains?"
Curtains be behind the couch.
I have found the metal part you slide up and down to control temperature just lying on the shelf. I assumed it vibrated off over time traveling bad roads.
All roads are getting worse. Ain't nobody got no money to fix no toads...
TAC #MS-10
Airforums #70955
Old 03-12-2014, 06:50 PM   #18
r carl's Avatar
Lin , Ne
Originally Posted by Inland RV Center, In View Post
What causes that tubing to break???
Lack of proper running gear balance (vibration).
If the aluminum tube is vibrating, it will fatigue and break.
Old 03-14-2014, 11:19 AM   #19
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
1997 safari Dometic RM 2652
Correcting prev input. RM 2652 is correct model. Replaced OE thermister with a Articca adjustable thermister. NO change. Fridge still too cold. AC power only so far. Have NOT run on propane yet.After changing the thermister, what part would be next to look at ? Have been turning fridge on and off to keep temp somewhat under control. Something needs to be telling the AC heater to stay on vs: cycling on and off to maintain proper temp. All input is appreciated.
Jim & Mitzi is offline   Reply With Quote
Old 03-14-2014, 11:52 AM   #20
The electric thermostat is shot.
Old 03-14-2014, 01:06 PM   #21
2014 16' Sport
Route 66 , Arizona
Brand new fridge in our SOB never kept things cold enough.
Brand new fridge in our Bambi keeps things too cold.
We consider this a very pleasant "problem" to have.
Don't necessarily believe we've bought two new RV's in a row with broken fridge parts.
Regardless, thank you Airstream for besting our SOB in yet another aspect.
Skooter is offline   Reply With Quote
Old 03-14-2014, 01:45 PM   #22
2005 19' Safari
GLENDALE , AZ
You might try a recirculating fan in the refrigerator section. This will help even out cold and hot spots on the inside.
Amazon.com: http://www.amazon.com/Camco-44123-Fr...frigerator+fan
Note: Item also available at WalMart and Camping World.
Old 03-19-2014, 12:28 PM   #23
1990 34' Excella
1990 29' Land Yacht
Please provide the thermostat probe pic or part number. Does Inland RV carry it. Your input is greatly appreciated. Jim C.
Old 03-19-2014, 12:35 PM   #24
Depends on the reefers manufacturer and reefers model number.
Old 03-22-2014, 09:42 AM   #25
1990 34' Excella
1990 29' Land Yacht
Dometic RM 2652. In a 1997 Safari.
Old 03-29-2014, 07:37 AM   #26
1990 34' Excella
1990 29' Land Yacht
Andy, any pics or part # for RM 2652 1997 Safari Too cold.....
Old 04-13-2014, 09:25 AM   #27
1990 34' Excella
1990 29' Land Yacht
Andy. Any parts info? Gotta fix soon.
Old 04-13-2014, 09:33 AM   #28
I will be back in my office on APRIL 25th.
I am in a relax mode.
Aloha.
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
Food Trailer Custom Built Airstream (Food Truck) eBay Watch Airstreams on eBay 0 05-06-2011 08:00 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
Why does front A/C have drain hose but back A/C does not? AccessMaster Airstream Motorhome Forums 9 06-22-2003 07:15 PM
