Old 02-16-2015, 07:14 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Which Dometic to buy?
I have decided to replace the fridge in my 54 Flying Cloud with a modern Dometic. Current fridge sits in a modified opening smaller than the original. It appears that the original fridge/opening was 40 or 41 inches high. The two units I am considering are the RM2510 and the RM2551. In addition to being dimensional a bit different, the 2510 has bottom mounted controls and the 2551 has top mounted. I think both are electronic ignition. Anyone have either unit and care to comment?
BambiTex is offline   Reply With Quote
Old 02-16-2015, 08:08 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Norcold
2004 Excursion 4x4
Old 02-16-2015, 10:07 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Why is Norcold better?
Old 02-16-2015, 10:55 AM   #4
HowieE's Avatar
Images: 12
I have had 3 Dometics and none have ever worked above 80 degrees outside. Those that i know that have Norcolds don't seam to have that problem.
Others hopefully will comment but at this point i would never buy another Dometic.
2004 Excursion 4x4
Old 02-16-2015, 11:27 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think it has to do more with the insulation of the box than the actual cooling unit. Perhaps the cooling units are too small for the box.
Getting the heat away from the back of the unit is critical. But that is hard to do when the outside temps get above 80 or so. Warm air rises, but it doesn't rise well into air that is as warm or warmer.
With the advent of better batteries and inverters and solar. I see the ammonia refers becoming a thing of the past. Many large RV's are using conventional refers today.
Old 02-19-2015, 07:57 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Decided to go with Norcold N410. Will report back when in service.
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
1977 Excella 500 31', which Dometic do I have? tschat Refrigerators 4 07-01-2006 07:56 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
