Old 04-05-2008, 07:24 PM   #1
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
What to do?
I have a 1978 Argosy with a M100 Dometic refrigerator that is in good working condition. My concerns are due to it's age and that we do mostly boondocking and I am replacing the floor, would it be better to replace the unit with a new RM2620 or apply the ' if it isn't broke don't fix it rule?
Also How hard is it to install the new RM 2620 unit?
Regards,
JC
Argy 78 is offline   Reply With Quote
Old 04-05-2008, 07:38 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
If it were me and there was no reason to suspect problems, I wouldn't worry with it. If you do decide to switch it out, it is a straightforward job. Propane line, electric, a 12 volt line for the ignition hardware, and bolts it to the floor.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-05-2008, 09:15 PM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
My M50 (pink elephant) Dometic is still working from 1961 vintage. As I see it, you have at least 17 more years to go on yours.
As my dad always said, "Run it till the wheels fall off."
The worst that could happen is that you have to get a chunk of ice to get you through........
Sam
samb is offline   Reply With Quote
Old 04-06-2008, 02:53 PM   #4
Argy 78's Avatar
1978 Argosy 27
Fenton , Michigan
Thanks for the advice, I will let it go till it decides to retire.
Now I can get the front rock guards, two Fantastic Fans and still be under my original budget. Or was that just the tip of the ice berg?
Argy 78
Old 04-06-2008, 10:44 PM   #5
1977 31' Sovereign
Prineville , Oregon
I'm setting my AS up for boondocking most of the time. Because of the power consumption, I just decided to take the frig out completely. Mine was really heavy too so it lightened the trailer. What I've done instead is install a huge marine ice chest. I can put 2 blocks of ice in each end and over 2 weeks of groceries in it. The newer models are so efficient that they can keep food cold for a week in 95 degree weather. My experience has been at least that good. In moderate weather, a fill of ice is good for 2 weeks easy. Sometimes the simplest things are the best
David
DasAir is offline   Reply With Quote
