Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 06-29-2009, 06:22 PM   #1
Profile:  1959 22' Flying Cloud
Escondido , California
What is it and does it matter?
I was cleaning out my fridge fins and also the exhaust tube and the wire I was using got caught on something. After a lot of work it came out but it brought something with it. I'm not sure what it does but it looks like it would be used to make the exaust gases twist as they go up the stack. I'm not sure if I could put it back without taking out the fridge.
Attached is a picture of it. The wire shown with it was attached to it in the pipe. The twisted part was near the flame. Probably within a 6 inches of it.
What if any issues are there in leaving it out?
Gilbert
Name:	Frig Part 001.jpg
"On a vintage Airstream if it aint absolutely broke DON'T TOUCH IT!!"
2bkidfree is offline   Reply With Quote
Old 06-29-2009, 06:28 PM   #2
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
It looks like some homemade gadget. What is the twisty part made from?
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, WDCU & 4CU
Sugarfoot is offline   Reply With Quote
Old 06-29-2009, 06:35 PM   #3
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
It`s definately not home made,it goes back in the exhaust tube above the burner,it slows down and swirls the heat for better heat exchange.Put it back,if you want your fridge to work right.Dave
easyride is offline   Reply With Quote
Old 06-29-2009, 06:35 PM   #4
It's 1/2" wide, 6" long and about .020" thick. Here's a closer picture.
Name:	Frig Part 003.jpg
Old 06-29-2009, 06:38 PM   #5
Any ideas on how to get it back in? Can I disconnect the pipe from the burner and try to put it in from the bottom?
Old 06-29-2009, 06:45 PM   #6
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Images: 40
Airstream Registry
It should go right back in just like it came out. If it gets stuck, try rotating it slowly. It needs to be in place for the fridge to distribute the exhaust heat properly.
FF
WBCCI/VAC #2699
Air #10
AZ-1
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 06-29-2009, 06:47 PM   #7
Sugarfoot's Avatar
OK, now I have a question. Do I have one of those things hanging down my refer exhaust? I've never looked.
Old 06-29-2009, 06:48 PM   #8
naples , Florida
The whole burner assembly is right below the tube,that would have to be removed,which isn`t that easy,also the little bend on the top of the difuser needs to hook on top of the tube to have the difuser the correct height above the burner.??? Pull the fridge.Dave
Old 06-29-2009, 06:50 PM   #9
naples , Florida
Fridge
If you have a Dometic ,yes,that`s the only brand I have torn apart.Dave
Old 06-29-2009, 06:54 PM   #10
flyfshr's Avatar
Phoenix , Arizona
Images: 40
Airstream Registry
SugarFoot ~
My Dometic isn't original to the TradeWind so I'm not sure if you have one or not but I'll bet yours is similar.
FF
WBCCI/VAC #2699
Air #10
AZ-1
Old 06-29-2009, 06:57 PM   #11
How it came out was not pretty. Lets just say it was one of those:
1. It's getting dark.
2. I've been working on it for hours.
3. Either it's coming out or something is going to break.
If I can't get it back in and the fridge doesn't work the wife is going to believe that I planned it because I've been talking about getting a new fridge for awhile.
Of course I wouldn't do that!! See "new riding mower, compound miter saw, etc."
Old 06-29-2009, 07:11 PM   #12
Sugarfoot's Avatar
I learn something everyday. My refer is the original 1960, and based on 2b's experience, I'm not going looking for that little device.
2b, I hope all works out well.
Old 06-29-2009, 07:19 PM   #13
flyfshr's Avatar
Phoenix , Arizona
Images: 40
Airstream Registry
If your fridge is working fine, why would you?
FF
WBCCI/VAC #2699
Air #10
AZ-1
Old 06-29-2009, 08:00 PM   #14
Snowball.
It was one of those snowball effects. While up on the trailer I noticed that the fridge vent cover was broken so I ordered a new one from Vintage Trailer Supply.
The fridge never worked really well. It made what I would call soft ice.
After removing the old cover I was looking up from the bottom saw that there was a ton of leaves and junk along with a hornets nest in the cooling fins. I was cleaning them out thinking that this would improve the performance and decided to clean out the exhaust while I was at it and the rest is history.
Gilbert
Does Size Matter ? LisaP Member Introductions 40 06-13-2009 06:59 AM
It was only a matter of time... yukionna Off Topic Forum 1 04-14-2008 06:25 PM
Does size matter when towing? safari57 Tow Vehicles 8 03-06-2007 09:25 PM
Size Does Matter... aviontt Refrigerators 5 02-26-2005 11:45 PM
Does Airstream location matter? yukionna Buyer Guidelines 5 09-21-2003 11:54 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
