Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 06-30-2009, 08:50 AM   #15
grtwhthuntr's Avatar
Profile:  1972 31' Excella 500
Lagrange , Kentucky
The leaves and the hrnets nest is what determined the performance of the fridge. The twisty thingy ( the name just will not come to me) is important to the operation and needs to be reinstalled the same way it came out. as was said before if it is stubborn, twist it and it should slide right back into place.
Good luck
grtwhthuntr is offline   Reply With Quote
Old 06-30-2009, 09:29 AM   #16
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
The twisty thing helps the draft in the burner tube, and will let the fridge be a little cooler. It has the handle on it so it can be removed to clean spider/mud dauber nests from the flue.
(No Longer at Inland RV)
Old 06-30-2009, 09:43 PM   #17
Profile:  1959 22' Flying Cloud
Escondido , California
So, any ideas on how to put it back in the tube without pulling the fridge? Attached is a rough sketch of the exhaust piping. Just above the burner there is a metal pipe that goes into an insulated aluminum box. This whole assembly is about 27". A second tube that is 36" long connects to this. At the base of the second tube are 4 vent holes and a phillips screw. Please note that I can't see most of this, but I can feel it.
I was thinking of trying to take out the phillips screw, moving the top vent and trying to insert the "thingy". I can hook it to one of the vent holes.
At this point I don't want to make things worse, so if this is a bad idea let me know.
Thanks for all the help. Learn something new every day.
Gilbert
"On a vintage Airstream if it aint absolutely broke DON'T TOUCH IT!!"
2bkidfree is offline   Reply With Quote
Old 07-01-2009, 09:47 AM   #18
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
If you can lift the top vent pipe out of the way, then somehow get the difuser to go back in ,just hook the wire over the bottom pipe,then reinstall the top pipe.Good luck!!
Dave
easyride is offline   Reply With Quote
Old 07-01-2009, 01:22 PM   #19
Profile:  1966 22' Safari
Keller , Texas
Check out rvmobile.com for a beautifully detailed description of how your fridge works. They say that baffle is a necessity, and that it has to hang at just the right height.
Old 07-01-2009, 06:01 PM   #20
Mimiandrews, Thanks for the site. It was very very helpful.
So, it's called a Baffle and it has to be at the correct height. I guess I know what I'm doing this weekend.
I'm going to try Easyride's idea and just see if I can move the upper pipe over. Hopefully the baffle is self centering.
Thanks to everyone for all the help. I'll let you know what I come up with.
Gilbert
Old 07-01-2009, 06:12 PM   #21
naples , Florida
The pipe it goes in is just a little bit bigger than it is,so yes if you get it in there ,it will be in the center.Dave
Old 07-07-2009, 06:48 PM   #22
It's in.
Well, it took a little work, but it's back in the pipe. The freezer works but the fridge is still dead. Maybe Santa will get me a nice used one.
Gilbert
Old 07-07-2009, 07:01 PM   #23
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
Unhappy Not Cool
Sorry to hear that. A little Christmas in July, maybe???
I know there are a number of places on the web that deal in rebuilt refers.
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, Washington DC Unit
Sugarfoot is offline   Reply With Quote
Old 07-08-2009, 09:38 AM   #24
Keller , Texas
Sorry to hear you're still having trouble.
T.J., the guy at rvmobile.com, rebuilt the cooling unit for our fridge--not cheap, but good workmanship. He was kind enough to talk me through the whole thing, although if it's on his website, he's not slow to tell you to go read it first. Call him if your problem's not on his site. If one part of the fridge works, I can't see why the whole thing won't--isn't it one cooling unit?
After I reinstalled the cooling unit, I was able to test our fridge in the shop with a barbeque propane bottle and regulator before I reinstalled it in the trailer. Ran it on both gas and electric, and it worked fine.
I had never worked on a gas/electric fridge before in my life, and T.J. got me through it. He has my recommendation!
Old 07-08-2009, 11:34 AM   #25
naples , Florida
Angry Cooling
Gilbert
How long did you let it run ? If the freezer is working,the fridge should also.
Dave
Old 07-08-2009, 11:39 AM   #26
RangerJay's Avatar
Profile:  2002 19' Bambi
Northwestern Ontario , Just above the big green spot
If I can't get it back in and the fridge doesn't work the wife is going to believe that I planned it because I've been talking about getting a new fridge for awhile.
.... yup .... pretty much looks like you need a new fridge to me .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2003 (The Buggy)
RangerJay is offline   Reply With Quote
Old 07-08-2009, 11:28 PM   #27
It ran for atleast 12 hrs. The freezer made ice but the fridge was room temperature. I'm guessing it has other issues. The wiring below looks like someone colorblind put it together. I'm not even sure if the thermostates work.
I'm new to the propane fridge world so I could be doing something wrong. I thought if the freezer worked the fridge had to too. But nope. We're going camping this weekend so it'll have a good long run.
Gilbert
Does Size Matter ? LisaP Member Introductions 40 06-13-2009 07:59 AM
It was only a matter of time... yukionna Off Topic Forum 1 04-14-2008 07:25 PM
Does size matter when towing? safari57 Tow Vehicles 8 03-06-2007 10:25 PM
Size Does Matter... aviontt Refrigerators 5 02-27-2005 12:45 AM
Does Airstream location matter? yukionna Buyer Guidelines 5 09-21-2003 12:54 PM
