Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 03-17-2008, 02:48 PM   #1
monocoque
monocoque's Avatar
Profile:  1975 29' Ambassador
San Antonio , Texas
What to do with a 32 year old refrigerator?
I'm in the process of a driveway shell-off to replace the frame on my Ambassador. Frame Rot So far have I removed the refrigerator, along with about half the interior, and now the refrigerator is sitting on the driveway. So now I have a question: What does one do with a 32 year old refrigerator? It's a Royal Dometic, gas/electric, automatic defrost, model rm100. I have no idea whether it works or not. Although some of the knobs have either broken off or fallen out of position. Plug it in and see what happens?
ID:	56464  Click image for larger version
ID:	56466  Click image for larger version
monocoque is offline   Reply With Quote
Old 03-17-2008, 02:53 PM   #2
DavidsonOverlander
DavidsonOverlander's Avatar
Profile:  Milton , ON
Originally Posted by monocoque
What does one do with a 32 year old refrigerator? I have no idea whether it works or not.
It might still work. The one from our '64 Overlander didn't quit until it was 42 years old, and then only because I couldn't find a small part for the burner.
I still have it if anyone needs any parts off it.
Grant Davidson
Milton, ON
1964 Overlander
2005 F-350 SRW 4x4 crew cab long box
1965 Avion C-10 Truck Camper
DavidsonOverlander is offline   Reply With Quote
Old 03-17-2008, 03:25 PM   #3
monocoque
monocoque's Avatar
San Antonio , Texas
Grant, so would you suggest I just plug this one into 110 and see what happens? It has been suggested that it might not operate without the proper ventilation?
Todd
Old 03-17-2008, 04:44 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Todd
You can plug it into 120, it won't need to be vented.
Change is inevitable, except from a vending machine
AIR#2611
Old 03-17-2008, 06:18 PM   #5
drag'nwagon
drag'nwagon's Avatar
1956 26' Cruiser Overlander
Lambertville , Michigan
Mono,
There are few outfits around that will make the old Dometics like new again for a lot less than a new one. Considering all the trouble everyone has with the new reffers and circuit boards it may be worth having it re-done. I can't remember the name of the one company in Elkhart that specializes in Dometics.
Dave
Operation "Save Rudy" Strike Team (charter member)
You mess with the Strike Team,... you mess with the whole trailer park!!
drag'nwagon is offline   Reply With Quote
Old 03-17-2008, 06:41 PM   #6
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Try it. The one in my ’67 still works. The door is about to disintegrate, though.
Vaughan
Old 03-17-2008, 06:48 PM   #7
rmpray
rmpray's Avatar
Profile:  1973 31' Sovereign
Bertram , Texas
Images: 21
Just because it is out you might as well invert it for a night and then right it and see if it cools well. Sounds odd but you'll find that process in some of the threads and I had found it in a handy dandy RV service manual. THat breaks up any crystles that may have formed in the ammonia lines. Several have commented that this process had their refers running like new. Some have suggested gently thumping the lines with a rubber mallot...but not sure if that is neccessary. If it runs on electric, then your issue will be if the gas burner works. If so, you should be good to go.
rob
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 03-18-2008, 09:05 AM   #8
monocoque
monocoque's Avatar
San Antonio , Texas
Okay, I'll look around for a company that rebuilds Dometics. And I'll plug it and see what happens. I did invert it momentarily when I lowered it down and out through the door of the trailer. Afterward there was a very strong ammonia smell which seemed to be emanating from freezer, at least the smell was quite strong when I opened the freezer door?
Todd
Old 03-18-2008, 12:54 PM   #9
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Todd
That is bad news. Don't bother plugging it in. It is DOA. These refers are filled with ammonia. It is the main chemical in the heat absorption refer. Your choices now are rebuild the one you have or get a new one.
Try these sites : RV ice box , RV mobile
There are a couple other sites that I can't find right now that explain quite well how an ammonia refer works.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 03-18-2008, 02:29 PM   #10
monocoque
monocoque's Avatar
San Antonio , Texas
Chris, I assume then what I have is a leak which became apparent when I inverted the unit during the takeout. The sites to which you refer make a strong case for a repair versus replacement. I wonder what shipping from and back to San Antonio would cost? Would need to factor that into the cost of repair vesus replacement. Hmmmm...
Old 03-18-2008, 02:56 PM   #11
C Johnson
C Johnson's Avatar
Portland , Oregon
Images: 326
Yes, It sure looks that way. The cooling coils are in the freezer that makes sense that the smell would be coming from there.
I have been watching your frame thread. Pretty interesting stuff there. I have been sorta looking for a larger AS which is why I have been looking at what your are finding out with yours.
In My Opinion, I would worry about the refer later, but keep an eye out for a great deal on a new one or used.
When I did my frame off I had a hard time, at first, focusing on one thing at a time and prioritizing. After I prioritized things went really well. Again, just my .02
My Pictures
Old 03-18-2008, 03:02 PM   #12
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
A couple of years ago, we had our 1964 Dometic repaired...
http://www.airforums.com/forums/f425...ing-12068.html
The bottomline is the company we had fix it is:
Cool-Fun
15825 E. Edna Place
Irwindale, CA
626-960-5456
They did a terrific job and I would recommend them, if this is the route you wish to take. Cost of a new fridge: +/-$1000 (undercounter propane/elec model)
Cost of Repair: $350
Cost of Shipping to CA (FedEx Ground round-trip from CO): $200
Cost of keeping things vintage-original: priceless!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 03-18-2008, 03:54 PM   #13
monocoque
monocoque's Avatar
San Antonio , Texas
Cool-Fun
15825 E. Edna Place
Irwindale, CA
626-960-5456
Shari
Hi Shari, Good and that give me real numbers to compare a rebuild versus a replace. It's nice to know these older units are repairable at a cost cheaper than replacement.
Todd
Old 03-18-2008, 04:00 PM   #14
monocoque
monocoque's Avatar
San Antonio , Texas
Chris, feel free to join the frame thread. I appreciate your .02! I need all cents (sense) I can get there. I haven't found an example in the forums of a drive-way shell-off frame replacement...yet. Was your frame-off done in the driveway? So mine may be a first?? It's a big job and one I almost backed out of. I agree about staying prioritized. But during the week, here at the office, it's nice to explore other issues...I can't seem to resist! Especially since the refrig is just sitting there in the driveway.
Todd
After one year . . . Marisue Member Introductions 5 09-17-2007 09:05 PM
What a year it has been! thecatsandi Full-Timing 16 04-24-2007 08:30 AM
39 year old Dometic Refrigerator BobbyW Refrigerators 24 05-10-2006 02:35 PM
Engine/Year Trans/Year Matrix 1985air345 Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 07:40 PM
...and after one year..... Silvertwinkie Our Community 2 12-07-2004 07:04 PM
