Old 08-09-2015, 07:42 PM   #1
2016 30' International
Scottsdale , Arizona
What cooling should I expect from a new fridge?
We just picked up our 2016 30' Serenity.
I'm doing a test of the fridge right now and not sure if I am seeing what I should see in terms of fridge cooling performance.
Here is the scenario:
-Outside temp is around 100 degrees.
-Temp in the parked trailer (all windows open) is around 100 degrees.
-Fridge is empty
-Cooling setting is on HIGH (Coldest)
Empty fridge has been running on GAS, on HIGH, for 24 hours. Freezer temp is 16 degrees. Seems good to me! Fridge temp is 45 degrees. Not so great.
So, about 6 hours ago I switched over to running it on AC. Now, freezer temp is still 16 degrees, but fridge is at 52 degrees. (During the afternoon, the late day sun has been beating on the fridge side of the trailer.)
The fridge side of the trailer is facing west, with hot western sun hitting that side of the coach all afternoon.
Obviously, we are not occupying the trailer. It is parked beside the house. And the heat of the environment and temps inside the trailer cannot be helping the fridge do its job at all. And the fact that the fridge is empty... may be a factor as well?
Considering all this, does it sound like our fridge is doing its job as best as can be expected, or should it be cooling the refrigerator section a LOT better than it is?
Freezer performance looks great. Fridge performance is really causing us some concern, but we're not sure how much the environmental factors are influencing the performance.
DHart is offline   Reply With Quote
Old 08-09-2015, 07:59 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Inefficient RV systems will only cool so much. Sounds like you have reached that point. People expect too much from RV fridges and air conditioning systems. .
MICHAEL
Old 08-09-2015, 08:07 PM   #3
1994 34' Excella
Warren , Manitoba
I bought one of the inexpensive battery operated fridge fans to move the air in the fridge. Does help to keep things cooler and the batteries last about a month. Well worth the investment. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is online now   Reply With Quote
Old 08-09-2015, 08:14 PM   #4
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Is you fin slid all the way up? You r right, 45 will not keep food at safe temp for consuming. Talk to dealer.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 08-09-2015, 08:23 PM   #5
mandolindave's Avatar
DHart
Your fridge is doing OK. A little colder would be a little better. Being empty does make a huge difference. It being 100 degrees doesn't help. Your fridge is 45 degrees. That's 55 degrees colder than the temps outside. 10 more degrees and your milk and eggs would be close to freezing.
As far as giving it 24 hours, that's not too far off normal. People put cold drinks in their fridge to speed up the process. I put frozen water bottles in mine.
Once I get my fridge up to speed, in about 80 degree weather, it will freeze milk set on 3 ( about half way )
mandolindave is offline   Reply With Quote
Old 08-09-2015, 08:23 PM   #6
Yes, I do plan to talk with the dealer tomorrow. I was just wondering how well the fridges in other folks Airstreams are cooling.
I'm sure the 100 degree temp in the coach is playing some part in the situation. And the fact that the fridge is totally empty. But hoping that I can expect a little more from the Dometic.
Old 08-09-2015, 08:29 PM   #7
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
That's actually about normal cooling. I thought the best it could do was 30 less than ambient temp. And you're right, 100 degrees doesn't help. The hotter it is, the more it struggles.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-09-2015, 08:32 PM   #8
dznf0g's Avatar
Oswego , Illinois
After mods, with 100* and empty, I can get fridge to 38* and freezer to 2*.
-Rich-
Old 08-09-2015, 08:35 PM   #9
AWCHIEF's Avatar
Images: 33
What mods?
MICHAEL
Old 08-10-2015, 02:13 AM   #10
Yes, please share the mods. My wife and I have to get this ice box working better!
Old 08-10-2015, 06:29 AM   #11
dznf0g's Avatar
Oswego , Illinois
It was actually one repair and some mods:
Cooling unit went bad and I replaced with one from rvcoolingunit.com. They claim, (and I can see) better performance from re-routing some of the tubing on the cooling unit. They also claim a bit different Chemistry.
I addition:
1) three 120mm fans mounted just inside the top refer vent pulling air out of the back compartment
2) one 200mm fan mounted behind the lower access door pushing air in and up.
3) All fans controlled by a thermal switch. On and off at about 75* ambient temp.
4) Moved the thermistor down to the shelf with the plastic 4" X 4" tray in it; on the far right side, tip pointed toward door. (I never understood why it is mounted on the fins...turns the fridge on and off too frequently, IMO, on ALL fridges I have owned)
5) Interior twin 2" fans for the fin area from RVcoolinunit.com
I mount my remote temp sensor right below the drain pan for the fins...if I don't, I freeze everything in the back of the fridge.
When the outside temps are 90* and A/C is at 72*, the fridge (loaded) is at 34* (off) and 36* (on) in the fridge, and -2* (on) and -4* (off). That is on setting #3 of 5 for my model.
I had similar results on my old SOB, but some of the mods weren't available/known to me with that trailer.
-Rich-
Old 08-10-2015, 07:18 AM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Parking direction to the sun is important. In hot weather with the fridge side facing the sun we have had results similar to you. In these conditions I try to park the fridge side northerly, and to deploy the streetside awning to keep the area in the shade.
Our model has upper and lower fridge vent doors with a fan in the upper compartment. This helps moving air. I also prop open the upper and sometimes both vent doors to increase air flow.
The effort should be to keep the fridge compartment and airstream interior cool as possible. A well-stocked fridge and freezer will help stabilize fridge temps, some put a few milk cartons of ice in the freezer to help stability if there is not much else in there.
I think your fridge is operating normally in those conditions.
Doug and Cheryl
Old 08-10-2015, 08:02 AM   #13
CRH
1995 25' Excella
xxxxx , xxxxxx
I have done no mods to my 20 year old fridge. With the AC off and it 80+ degress in the trailer, my fridge is between 32 and 34 on the top shelf on setting #5....I confirmed this yesterday because I turned it on the day before and loaded it for a trip today.
CRH is offline   Reply With Quote
Old 08-10-2015, 08:05 AM   #14
AWCHIEF's Avatar
Images: 33
What is the outside ambient temp?
MICHAEL
How long should it take to start cooling? Roothawg Refrigerators 25 06-21-2013 05:35 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
What should I expect to pay for new brakes and tires Mary Burris Wheels, Hubs & Bearings 2 05-22-2012 06:59 PM
Should I expect some rattling from my Interstate? rv40 Sprinter and B-van Forum 12 03-18-2010 08:35 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
