Old 09-08-2003, 02:03 PM   #1
JMoy's Avatar
1966 17' Caravel
Redmond , Washington
Send a message via AIM to JMoy
Vent under Fridge on 66 Caravel
I finally had a key made to the access door under the fridge. To my surprise I noticed a wire mesh opening near the wheel well. Is this factory or a PO modification? If it is original, is it for venting? I looks as though water has mad its way in thru this vent and effected the wood cabinetry (which is ok since I am rebuilding the cabinets). If this vent is not original and dies not serve a purpose, I will close it up to prevent future water damage.
Jerry
JMoy is offline   Reply With Quote
Old 09-08-2003, 02:06 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My 68 Caravel has that vent just as you describe. I think it is necessary. I know mine is covered with a small furnace filter and there is a homemade windblock around the burner to keep it lit while towing.
Stephanie
Old 09-08-2003, 03:03 PM   #3
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
I have the identical vent as well. I also noticed some deterioration around the plywood flooring in this area, whereas the rest of the floor in my Caravel is solid. I have been tempted to cut out the marginal wood and re-build the vent somewhat smaller, but haven't because I've assumed Airstream knew something when they designed the hole so big!
Stef, I have a home-made looking windblock as well, made of galvanized (?) metal. Perhaps it wasn't homemade after all?
-- RL
rluhr is offline   Reply With Quote
Old 09-08-2003, 03:09 PM   #4
JMoy's Avatar
1966 17' Caravel
OK, so it is original! That's what I figured.
I have been contemplating a way to build a shield of sorts to allow air to flow but do a better job of keeping water out.
Thanks.
Jerry
Old 09-08-2003, 10:42 PM   #5
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
Improving the opening.
The opening allows cool air to enter as warmed air rises out through the "refer scoop" and roof vent. Unfortunately for me Airstream put my opening directly behind the tire and when I first bought my AS the opening and neighboring chassis was filled with dried mud and debris thrown in from tire rotation. So, first I cleaned it all out then built a metal chute with a screen to keep critters out and finished on the outside with a aluminum vent cover turned to keep splash out of the opening. Here's a photo of the chute or box I made with the screen screwed and caulked in place. Look past the screen down into the bottom and you can see the hood or vent cover I adapted to prevent splash.
Name:	refridg bottom vent_0052.jpg
Forrest is offline   Reply With Quote
caravel
Fridge Vent CampSayler Refrigerators 14 04-19-2005 03:11 PM
Vent replacement bathroom 66 Sovereign Rickj Roof Vents, Skylights & Fans 0 01-02-2004 06:34 AM
'66 Caravel Window hinge JMoy Windows & Screens 20 10-19-2003 10:42 AM
'66 Caravel Plumbing Picture Wanted JMoy Plumbing - Systems & Fixtures 7 09-30-2003 06:01 PM
