Old 12-03-2017, 10:15 AM   #1
martymcclain's Avatar
1961 24' Tradewind
Ventura , California
Vent space above refrigerator 1961 Tradewind 24.
I am wondering if there is anything missing from the venting area above refrigerator. I have had my 1961 Tradewind 24 for two months and I donít know if it works . Just want to be safe when I attempt to use it.
martymcclain is offline   Reply With Quote
Old 12-03-2017, 10:17 AM   #2
1961 24' Tradewind
Originally Posted by martymcclain View Post
i am wondering if there is anything missing from the venting area above refrigerator. I have had my 1961 tradewind 24 for two months and i donít know if it works . Just want to be safe when i attempt to use it.
Old 12-03-2017, 10:24 AM   #3
1961 24' Tradewind
ID:	300249this is the space above refrigerator....
Old 12-03-2017, 11:54 AM   #4
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
I assume there is no shelf material behind the aluminum upright. There is a gap so exhaust from the frig propane heater can escape up to a chimney cap on the roof. This looks the same as my 58 Overlander. Outside that screen is a chimney cap. On mine there is a outside louvered panel about mid way up the wall that is in line vertically with the upper screen and a screened opening in the floor/belly pan. Below the louvered panel is an outside access door that lined up with the propane burner on the frig.
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 12-03-2017, 12:13 PM   #5
1961 24' Tradewind
Thank you for your reply, yes, I have the chimney cap and you can see the screen opening in picture. I do not have louvered panel, but have an access door. I guess you would keep that open when operating the refrigerator.....
Old 12-03-2017, 01:46 PM   #6
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Maybe thats the norm for the era, I don't know...But with my vintage (91) the back of the frig is ducted up to the roof chimney, such that no combustion gas can enter the living compartment.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 12-03-2017, 10:39 PM   #7
1961 24' Tradewind
Yes, I was thinking the same as you concerning the combustion creating Carbon Monoxide. Hopefully someone can give me the 1961 era setup....
Old 12-04-2017, 12:32 PM   #8
1975 21' Globetrotter
Lincoln , California
You might consider adding the plastic ducking that you find on later models. There is a reason they added them (better ventilation) Do you have the floor vents sub/pan? They didn't have CO2 sensors back then either, no brainer there.
Good luck,
GA
sac1gaa is offline   Reply With Quote
Old 12-04-2017, 05:18 PM   #9
1961 24' Tradewind
Good luck,
GA
Thanks, thatís a great idea to upgrade an existing system. I will look into the plastic ducting. I will also install necessary sensors, better safe than dead.....
Old 12-04-2017, 05:37 PM   #10
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
That is correct for 1961, however if you're doing work in there I'd recommend creating an airtight flew up the back to help keep the exhaust gasses from backing up into the living space.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Old 12-04-2017, 11:31 PM   #11
1961 24' Tradewind
Thank you for the verification. I new someone would be able to tell me if anything was missing. Where would I find info in constructing an airtight Flue up the back?
Old 12-05-2017, 01:42 PM   #12
AlinCal's Avatar
1991 25' Excella
If me, I would get a sheet of aluminum and cut to width of cabinet + 1-1/2" to make a flange for each side of 3/4" (or so) and follow the curve of the inner shell with about 2-1/2" to 3" of space in between shell taking it up just past your roof chimney and bend to make a closure of that space. you can screw or use pop rivets to fasten flange to cabinet bulkheads, caulk as needed.
Will Rogers
Alan
Old 12-05-2017, 10:25 PM   #13
1961 24' Tradewind
Outstanding Idea and thank you for your help in solving my fear of combustion gases in my trailer. I will take pictures and post them to see your idea being created....marty
1961 Tradewind Fridge Vent beatrix1 Roof 9 05-13-2015 10:30 PM
1961 Space Liner douglasbury Airstream Trailer Forums 22 11-29-2012 08:21 PM
Switch above refrigerator in 67' safari Adair Lights - Interior & Exterior 4 01-04-2008 09:18 PM
What microwave above Excella's refrigerator? nickcrowhurst 1987 - 1989 Excella 2 10-10-2005 12:52 PM
