Old 05-03-2015, 08:46 AM   #15
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Wow. Technical stuff aside, glad you guys are ok.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-03-2015, 09:05 AM   #16
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
2 additional Forum points for Tommie.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-03-2015, 10:21 AM   #17
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Yep, sounds like Tommie got her. Lets hope so. Glad you guys have good sense of smell and thought to look around as well. Good luck
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-03-2015, 03:18 PM   #18
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I'll continue to keep an eye on it. The stack is clear, I pulled the fridge awhile back, and while I bolted it back in and returned all the screws, I might of hand tightened the connection and forgot to come back at it with a wrench, which could of been a costly mistake.
On that note, the wiring kit will remain a staple of my full-timers toolkit.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-03-2015, 07:48 PM   #19
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Glad all is well!
ďWhatís good for me may not be good for the weak minded.Ē
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-03-2015, 08:08 PM   #20
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
So the LP connection was loose?!?!?!?!?!?!?!?!?!?!
Wow...'that's a bomb. Also the LP is bad to breathe!!!! Mp lease get some yellow liquid gas sealant. It holds much better. Also the yellow GAS tape. Better stuff and the joints will have a hard time loosening. Not the "pot"'joints... The gas connections.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-03-2015, 08:56 PM   #21
Wolf Alaska's Avatar
Madison , Alabama
This example shows you don't always "get away with it".
Originally Posted by BoldAdventure View Post
Flash back from a leak at the LP connection. I used to soapy water, and also noticed that our 1 full propane tank is now empty today. 30lbs gone with minimal use.
Most safety oriented RVers agree that traveling with propane refers or other propane fueled appliances lit is unsafe. I never leave my refer on when traveling. And the propane tank valve is SHUT.
If this fire occured when you were fueling, it could have detonated fuel vapors. If this fire had been fanned by the slipstream, it could have consumed the trailer.
As it is, I would say that only good fortune saved your trailer. I doubt a propane detector would have alarmed as the refer hot section is o/s the living area.
As an aside, I once smelled an electrical fire in an RV as you did. It was burning wire insulation in the converter/wire bus bars. A loose wire connection caused a short & fire. It was right under the sofa & I could not miss it!
Compared to what could have happened, you "got away with it", almost.
Let's Roll !
Wolf
Wolf Alaska is offline   Reply With Quote
Old 05-04-2015, 05:31 AM   #22
Nomadic , USA
Let's Roll !
Wolf
Not the perception I've gotten reading this forum:
http://www.airforums.com/forums/f425...ing-76220.html
http://www.airforums.com/forums/f287...ng-118593.html
But I'll seriously think about it.
Old 05-04-2015, 05:52 AM   #23
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I turn mine off. Even on longer days in heat (90+) I haven't had problems with food getting warm. Just don't open it much on rest stops. And if the stop is long, you can turn it on.
Old 05-04-2015, 06:42 AM   #24
z , North Carolina
So glad to see you got this fixed Bold. As we leave this Friday for AZ, UT, & CO, it sure is nice to know I can post on here and get some immediate help. This board can be a lifesaver. Thanks to all who posted to give BoldAdventure the help he needed. I bought one of the gas sniffers for about 35 bucks from Lowes. You can bet your bottom dollar I will be using it when we camp on a daily basis. AND stick it in the Fridge compartment! From what I understand propane is more expensive than gas is in Utah.
Sea ya down the road.
Gavin
FishinHatteras is offline   Reply With Quote
Old 05-04-2015, 11:28 PM   #25
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have run with the fridge on LP... running down highways.. no problem. I have shut it off when I had extremely high side winds... just prudent.
My Dometic has the 'fix' .... which keep the flame contained.
In most cities you can find 'block' ice... or, if careful, you can use 'dry ice'... a little bit keeps the fridge really cool for a long time if left shut.
Channing
WBCCI# 30676
Help, 12 Volt TV melted the plug-in at wall. RLS Audio, Video & TV 6 04-14-2013 10:23 PM
baltimore - urgent pro photographer needed hainesfalls Off Topic Forum 2 08-27-2009 08:12 PM
Help newby to a productive afternoon - drill size? JoePfznik Ribs, Skins & Rivets 3 02-02-2009 10:44 AM
Urgent help needed baltimore remcolent Shipping & Export/Import 71 08-14-2008 10:28 PM
Urgent assistance needed for Sad UK Owners UK-Airstream Our Community 13 11-23-2005 04:52 PM
