Old 07-13-2015, 07:24 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
You have solar. That is really the key to extended off-grid operation of a DC compressor marine fridge.
Look at Isotherm and Vitrifrigo. Both made in Italy. Excellent quality at comparable pricing to RV fridges. These are my go to brands, depending on the size that I need.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-14-2015, 12:24 AM   #16
1974 Argosy 20
Kooskia , Idaho
Originally Posted by gecko View Post
Do you have any thoughts on our experience that we cool more quickly on shore power than we do on LP, when we know that the opposite is supposed to be true? Have you found that switching from shore power to LP on really hot days actually keeps the temperature lower for you, or does it just cool more quickly initially?
I suspect that your propane burner is not putting out enough heat so your cooling is not as good as it should be on propane.
Possible causes are:
Dirty burner caused by rust falling down from the boiler tube and partly closing the burner screen or outlet. It may need cleaning. Very common problem.
Burner mis located and not in center of boiler tube (rare but can happen)
Low pressure on LP gas lines, causing insufficient burner heat. Common issue, needs propane regulator adjustment to 11" water column or regulator replacement.
Partly clogged gas burner orifice causing low flame. Not common, but happens. Needs cleaning with alcohol and compressed air.
Spiders or other insects somewhere in the burner tube. Needs cleaning.
In general the propane burner create more heat than the electric element so is faster to cool down. Yours may not be up to snuff due to one of the above issues. The fact that it also wants to go out and not relight may also indicate one or more of the above issues is present, although I am not discounting the need for an air baffle to keep the burner lighting when traveling. I had one which was a new unit but the old air inlet simply caused the flame to blow out/not light.
Old 07-15-2015, 08:39 AM   #17
gecko's Avatar
2009 28' International
Pacific Palisades , California
Thanks for all the suggestions. We'll check them out!
gecko is offline   Reply With Quote
Old 07-15-2015, 09:01 AM   #18
1975 23' Safari
Bull Shoals , Arkansas
When I start my fag I bump up 5 then it goes back 1
Bud
gobuda is offline   Reply With Quote
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
understanding / discussing older floorplans darkStar General Interior Topics 5 08-10-2006 08:01 AM
Help in understanding trailer weights Silvertwinkie Our Community 6 08-08-2003 08:47 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 05:29 PM
