Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 12-26-2007, 11:45 AM   #1
N2XBW
N2XBW's Avatar
Profile:  Norfolk, In The Beautiful Saint Lawrence Valley of Far-Northern , New York
Question Two Out of Three Ain't Bad...
My Fellow Alumilovers,
The fridge in my '84 Excella 270 MH works 100% on both 110v AC and propane.
The 12v DC function does not operate.
Any suggestions as where to start? Thanks in advance.
John / N2XBW
Time is the only true currency. Spend it wisely!
'84 Excella 270vA.I.R.#14867
Last edited by Mel; 12-26-2007 at 11:47 AM. Reason: changed font to standard size 2
N2XBW is offline   Reply With Quote
Old 12-26-2007, 12:01 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
John / N2XBW
If it's the original, it does not have a 12 volt set up.
What is the model number?
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 12-27-2007, 09:16 PM   #3
Barkingspider
Barkingspider's Avatar
Profile:  Austin , Texas
Andy - That particular motorhome did have a 3 way fridge as original equipment from the factory. Also, the wiring diagram in the 1984 Airstream Motorhome Owners Manual shows a 25 amp fuse on the chassis fuse block that powers the wipers and the refrigerator.
John - First thing I'd do is confirm that the fridge is actually receiving power from the chassis fuse pannel. To do this first check to see if the wipers are working (as I mentioned above the fridge and the wipers are on the same fuse). If they are then you know the fuse isn't blown. Next I'd check the wires at the fridge to see if you are getting power from the chassis fuse block (seperate from the ignitor run) which should come from the coach battery. If you have power on the chassis wires then you know it's the fridge.
Let us know what you find. If power is confirmed someone else on the forum will need to jump in and help with diagnosing the actual refrigerator 12V operation.
Good Luck!
Joe
Barkingspider is offline   Reply With Quote
Old 12-28-2007, 08:07 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
Having 12v is not always good. I don't know if it's just coincidence, but the 3 way fridges that I have seen with bad circuit boards have been running on 12v. The 3 way fridge in our Overlander was deliberately left off the 12v feed for cooling.
Change is inevitable, except from a vending machine
AIR#2611
Old 12-29-2007, 11:01 AM   #5
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
I agree with Terry.
I did not hook up th 12V in my Flying Cloud either. When I don't have 120V I use propane. I don't want to kill my battery by mistake and then be without that resource to run everything else.
Barry
Barry & Donna
Life is short - so's the door on an Flying Cloud (ouch)
1951 Flying Cloud 21'
1957 Pontiac Safari 2dr wagon TV
AIR #7364 WBCCI #8110
safari57 is offline   Reply With Quote
Bad as it looks? sumsmug Repairing/Replacing Floor &/or Frame 4 09-17-2007 09:44 AM
how bad is too bad a dent? piratesteve Exterior Restoration Forum 21 09-05-2006 07:11 PM
What is this...can it be bad?? dragonnfly Electrical - Systems, Generators, Batteries & Solar 11 05-28-2006 02:41 PM
Bad Bad Things... (a new 454 Engine?) pillageTHENburn Mechanics Corner - Engines, Transmission & More... 24 12-19-2005 12:49 PM
How bad have you got it? 69Ambassador Our Community 6 10-25-2003 04:08 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
